LED DRL replacement - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 31 (permalink) Old 06-02-2011, 09:32 AM
Re: LED DRL replacement
Doh... wish I would've read this thread before making a new one. So for Canadian 3's the Nagare headlight details are the DRLs? I assume if I wanted to change the bulb(s) on mine (which doesn't have DRLs) they'd be the same? T10 is the form factor?
"I feel sorry for people who don't drink. They wake up in the morning and that's the best they're going to feel all day."
"We could talk or not talk forever.. and still find things to not talk about."
mu1980 is offline
post #12 of 31 (permalink) Old 06-03-2011, 09:15 PM
OI... OK I went through this myself... The US 3 Bixenons have the Wedge 194 in this position. The Canadian one has the h8 as a DRL in the same position. The thing that's ultimately confusing which noone on here would address is the fact that when you look at the T10 that they show in theSpeedline photo (the one that shows the bulb lit up in the headlight) shows JUST the accent light lit up by itself; BUT the bulb they sell is the T10 led whick can ONLY operate with the amber parking light UNLESS you do the parking light delete. So they either did that or photoshopped it; BUT I took a shot, it works well for the US 3 and mine look awesome. whew
sotrbox is offline
post #13 of 31 (permalink) Old 07-28-2011, 04:11 AM
Hey sotrbox, I drive an Australian MS3 with the W5W (T10) bulp. I've been trying to work out how the Candadian cars have DRL's in the same position. The W5W bulp is piss weak.
So you've just mentioned this H8 bulb, which is a serious headlight type bulb... see below...
I've been dicussing this with other US forums and took a photo of what the Australian Cars bulb look like...
In the below pic, you can see a grey plastic mount label 1 that the W5W (T10) buld mounts in. What I want to know is what the Candadian bulb mount looks like...Interesting I think that grey mount actually comes out of the black base label 2.
So maybe I can have Candadian DRL's afterall, just need a H8 bulb. I wonder if the fuse is a higher rating though...
Best Mufflers DP | 200 Cell CAT by 2XS | 3" Custom OPEN System with MAGNAFLOW Muffler & 4" tips | Speedy Lite Fin 18" Alloys with Sumitomo HTR ZIII |
CORKSPORT SRI-TIP-Airbox | DGR Coilovers
| OPTICOAT by ZAS | 2XS LED Fogs | 68 SMD LED (in the post) Parkers | Rear LED Reflectors | Hollandia 700 Sunroof | EYELIDS by MPS | Visual Garage Shark Fin Antenna
Yeldarb is offline
post #14 of 31 (permalink) Old 07-28-2011, 04:41 PM
I really dont know what the difference is with Australian 3's; Only CA is specified to be different in our manuals. If I'm correct it looks like yours come with an LED w5w in that picture??; ours come with a cruddy weak halogen bulb, the same one for our license plate bulb. I think its a bit more than plug n play as far as just switching out that gray thing, or a fuse in order to change that bulb type but I could be wrong. The CA DRL looks weak anyway IMO; how much light could you expect from the DRL anyway. Personally I love the way my t10 30 SMD led looks in there and it totally works as a DRL because I also have a VLED switchback LED in the 7443 ( blinker ) position. The two of them on make it look like the whites of the "eyes" are glowing whitish blue like 6-8k temperature; effectively I've created my own DRL which I like much better that most cars. It looks awesome at night though you shouldn't drive with no headlights on; but from oncoming it looks hella bright and almost like those are headlights; for cloudy days or early evening they're perfect. If I can get a good pic later Ill post it; the glare at night makes it difficult to capture but it looks totally sweet.
sotrbox is offline
post #15 of 31 (permalink) Old 07-29-2011, 09:54 AM
GrifN's Avatar
[quote author=sotrbox link=topic=182552.msg4081809#msg4081809 date=1311882108]
My
Build Thread
should never be forgotten.
GrifN is offline
post #16 of 31 (permalink) Old 08-03-2011, 03:53 PM
OK I finally got around to gettin some photos up and theyre not the best but you get the idea. The one from behind the car will show that they actually put out some light by themselves; although again the pix dont do them justice. Now lets see which posting method works this time; this is only my second pic post so here we go...
sotrbox is offline
post #17 of 31 (permalink) Old 08-08-2011, 06:52 PM
sp3
Damn, that looks clean.
Why would Mazda use 2 different bulbs for the same system?
sp3 is offline
post #18 of 31 (permalink) Old 08-10-2011, 07:32 AM
in the last picture you posted, it looks like that amber piece on the headlight is gone, did you take it out?
that's one thing i don't like on the headlights ;x
Dennis805 is offline
post #19 of 31 (permalink) Old 08-10-2011, 03:23 PM
GrifN's Avatar
[quote author=Dennis805 link=topic=182552.msg4090482#msg4090482 date=1312972362]
Looks like he replaced it with a clear one?? I'll be baking (well, heat-gunning) my headlights open next week and spraying some black in there.
My
Build Thread
GrifN is offline
post #20 of 31 (permalink) Old 08-15-2011, 10:40 PM
You might need to adjust the brightness on your screen, but check this out.
Top line says Canadian H8, Bottom line say Others W5W.
So, easy as that. I'm thinkinig of stick these in the slot...H8 HID conversion kit.
But right now I have these installed (the 68 SMD LED on the left)
Looks' like this out...
And installed
While I was at it, I changed the reverse lights out as well...
Old halogen colour,
New LED Colour
Old and new compared side by side...
And this is what the bulbs look like...
[img width=573 height=768]http://i797.photobucket.com/albums/yy251/Yeldarb13041975/f8304959.jpg[/img]
Yeldarb is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/375242-led-drl-replacement.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-29-2015 04:06 AM
