2010 MS3 3rd brake light cover removal - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 2 (permalink) Old 06-30-2010, 01:25 AM Thread Starter
hello,
wanted to ask if anyone here knows how to remove the 3rd brake light cover from 2010 MS3? i want to tint it red. thanks in advance
Velocity Red Mica :: 2010 Mazdaspeed 3
akosiharold_510 is offline
post #2 of 2 (permalink) Old 07-06-2010, 04:36 PM
Re: 2010 MS3 3rd brake light cover removal
The information I have is that it is best to remove the spoiler to do this, these are the instructions I was given.
You will need to remove the spoiler to get to it. there are 4 nuts that hold it as well as some clips. 2 nuts under the plastic plugs at the top of the tailgate when you open it and 2 under the plastic trim in the middle of the tail gate. The trim just pops off.
Make sure you unplug the brake light which is located under the trim piece as well. All the nuts are 10mm if i remember right.
Once the nuts are removed its held on with about 4 plastic clips. If you close the tailgate and just pull kind of up and back it will pop off. It requires a bit of pulling but i have had it off 3 times or so and it wont break.
Then once its off there are 4 screws that hold on a plastic cover, take that off and take off the next 4 screws holding on the brake light and it will come off.
Let me know if this helps, this is on my list of exterior mods.
Zman
Zman - 2010 MS3
CS SRI/TI | HKS SSQV4 | CPE HPFP | CPE FMIC | Cobb DP | UR CBE | TMW SS Replacement | BC Coilover | Hawk HPS w/SS lines | CPE RMM SMM | Forgestar F14 staggered | JVC HU/JL amps/speakers/subs | Bunch of non-HP stuff
Current Projects: Meth Kit | Inj Seals in Garage | EM on order | IM being Sorced | Working interior issue
ZPrice is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/368381-2010-ms3-3rd-brake-light-cover-removal.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-27-2015 08:52 PM
