TSX-R 2.5" Clear lens - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 13 (permalink) Old 02-14-2010, 01:27 PM Thread Starter
Would there be a problem if I swapped the stock halogen projector lens with a TSX-R clear lens?
http://store.theretrofitsource.com/p...af2184f915cdc5
Thanks!
monzttr is offline
post #2 of 13 (permalink) Old 02-14-2010, 01:36 PM
Re: TSX-R 2.5" Clear lens
If the diameters are the same, then there's no problem.
2007 Mazdaspeed3 GT
armanrus is offline
post #3 of 13 (permalink) Old 02-14-2010, 02:52 PM
Each lens has different refraction ratio. Same diameter isn't indication of compatibility..
2010 projector is Koito projector and optic charactor is close to MDX, Camry projectors. ( TSX:stanley)
I remember TSX's 2.5" lens is slightly smaller than Koito 2.5" and there is minor refraction ratio difference too.
I could get close enough output on MDX sample, but not sure if 2010Mazda3 use same Koito projector like MDXs...
Contact TRS for spec and compatibility to make sure if they can be used in 2010.
upashi is offline
post #4 of 13 (permalink) Old 02-14-2010, 04:48 PM Thread Starter
I have emailed TRS in regards to a clear lens solution for the 2010 Mazda3, I will post updates to this thread.
Thanks.
monzttr is offline
post #5 of 13 (permalink) Old 02-14-2010, 05:09 PM
I have my 2010 Halogen projectors out of the housing, I can swap in a few lens and test them for you.
IMO, the projector is really dinky and not worth the $70 for the clear lens. If you are already cracking the housings open and have the confidence to do a little cutting, just retro a set of HID projectors.
3remix is offline
post #6 of 13 (permalink) Old 02-14-2010, 05:24 PM Thread Starter
[quote author=3remix link=topic=167255.msg3546697#msg3546697 date=1266185367]
I just wanted to do the clear lens mod, I don't know if I am ready to do a complete retro! Is there a retro that would not require any cutting?
Do have lenses you can test or did you want me to send them out to you?
monzttr is offline
post #7 of 13 (permalink) Old 02-14-2010, 09:47 PM
Hmm, you may be able to get away with no cutting by using a smaller projector, the S2k's I have in mine are pretty fat, so I had to cut away some material to make it sit properly. This was one of the easier retrofits I have done, and I am sure if you plan it properly, it will go well
For doing just a lens swap, I ll test the projector on different clear lens maybe later tonight if I have time. I have a few 2.5" lens left sitting around that I can test for you. Off the top of my head (AP1 S2k, FX Frosted, Celica clear lens, RX330 Fresnal and maybe a few more if I can find them).
[quote author=monzttr link=topic=167255.msg3546709#msg3546709 date=1266186279]
3remix is offline
post #8 of 13 (permalink) Old 02-14-2010, 11:08 PM Thread Starter
[quote author=3remix link=topic=167255.msg3546963#msg3546963 date=1266202044]
Thank you! This is much appreciated.
monzttr is offline
post #9 of 13 (permalink) Old 02-15-2010, 10:49 AM
Send a message via AIM to astrob0y
I wwanna see some pictures of the s2ks!!
astrob0y is offline
post #10 of 13 (permalink) Old 02-16-2010, 10:39 PM Thread Starter
After talking with Matt at theretrofitsource.com, I've decided to try the TSX-R lenses. I will post some pics when I am complete (hopefully this weekend).
monzttr is offline
