2010 MS3 Inside/Outside Bulb Numbers??? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 11 (permalink) Old 02-08-2010, 02:09 AM Thread Starter
Any Ideas??? The manual lists some per se, but I really want the trunk, overheads etc...
Headlights = HB3 / 9005 for highs AND H11 for Low's and Fog's
Looking to switch out the inside lights to LED's and also the license plate lights... The manual lists the license plate as W5W?? That "trend" means 5 watt... Also tried running google to no avail... Sylvania posts up to 2009 series (Gen1's).
Thanks!
Bry H
2010 Mazdaspeed 3 w/tech pkg - CP-e SRI - PG TIP - Forge V2 BPV - UR Test Pipe - JBarone Shifter w/retro kit & Solid Mounts - Dogbone RMM -Purchased 1/23/2010
2006 Mazda Grand Touring Sport Hatch loaded.....
2005 Mazda Sport Hatch......
"Trust is something that comes easy when you never been a Victim"
3Sleeper is offline
post #2 of 11 (permalink) Old 02-08-2010, 08:50 AM
Re: 2010 MS3 Inside/Outside Bulb Numbers???
Fogs are 9006/HB4
Domes/Map are T-6 or 31mm
Hatch Bulb is a t-6 as well.
ReD~DrAgOn is offline
post #3 of 11 (permalink) Old 02-08-2010, 09:09 AM
[quote author=3Sleeper link=topic=166800.msg3535958#msg3535958 date=1265612946]
Thanks!
Bry H
Here is my list of what I used (2010 MSP3):
I got mine at superbrightleds.com
Reverse light - 7440-WLX3
Plate lights - WLED-x6 (2 req)
Map/Dome/Hatch Lights - 3022-x9 Festoon
Glove box - WLED-x6
x = Color choice
Simple installs, you have to jerk the glove box, quick disassembly, only two screws.
Enjoy
Zman - 2010 MS3
CS SRI/TI | HKS SSQV4 | CPE HPFP | CPE FMIC | Cobb DP | UR CBE | TMW SS Replacement | BC Coilover | Hawk HPS w/SS lines | CPE RMM SMM | Forgestar F14 staggered | JVC HU/JL amps/speakers/subs | Bunch of non-HP stuff
Current Projects: Meth Kit | Inj Seals in Garage | EM on order | IM being Sorced | Working interior issue
ZPrice is offline
post #4 of 11 (permalink) Old 02-08-2010, 02:21 PM Thread Starter
Posted by: ReD~DrAgOn
Fogs are 9006/HB4 --- In the manual it lists H11 55 watt!! 9006 are Gen1 fogs.. So which is it???
Domes/Map are T-6 or 31mm ---- 3022 = Thanks ZPrice
Hatch Bulb is a t-6 as well ----- 3022 = Thanks ZPrice
3Sleeper is offline
post #5 of 11 (permalink) Old 02-08-2010, 04:37 PM
[quote author=3Sleeper link=topic=166800.msg3536730#msg3536730 date=1265656909]
Fogs are H11, just put in some yellows
Zman - 2010 MS3
ZPrice is offline
post #6 of 11 (permalink) Old 02-08-2010, 05:42 PM Thread Starter
ZPrice coming thru again.... Thanx bro!
Yeah I got worried because I just ordered a set of yellows last night!
3Sleeper is offline
post #7 of 11 (permalink) Old 02-17-2010, 11:02 AM
So both headlight low and fog light are H11? just wanna confirm before I order, since manual said 9006 for fog. =X
shingojr is offline
post #8 of 11 (permalink) Old 02-17-2010, 07:42 PM
2010 Mazdaspeed 3's are H11 for low and fog.
2010 Mazda 3's are 9006 for fog and H11 for lows.
ilal2ielli is offline
post #9 of 11 (permalink) Old 02-17-2010, 09:29 PM
[quote author=ilal2ielli link=topic=166800.msg3552134#msg3552134 date=1266453730]
Correct, I just listed the bulbs that I used for my Car.
post #10 of 11 (permalink) Old 02-21-2010, 11:00 AM
Does anyone know the size of the side mirror lights? There should be two of them in the mirror?
magicman is offline
