Swirl flap preventetive maintenance - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 3 (permalink) Old 12-31-2019, 12:55 AM Thread Starter
judgem's Avatar
Question Swirl flap preventetive maintenance
Hi All,
Recent owner of a 2009 Mazda 3 BL. When researching known issues before purchasing this car, I have been told about some swirl plate thing in the intake manifold that can break and get sucked into the engine and destroy it.
I would like to know when do I need to sort this out before it becomes an issue. I have 68000kms on the car currently.
Regards,
judgem is offline
post #2 of 3 (permalink) Old 12-31-2019, 11:01 AM
Super Moderator
shipo's Avatar
Originally Posted by judgem View Post
Hi All,
Regards,
What is a Mazda3 BL?
I had a 2009 Mazda3 i and never heard of a swirl plate; that and I haven't heard of any such thing on any of the Mazda forums I participate in.
2006 Acura TL 6-Speed Manual
shipo is offline
post #3 of 3 (permalink) Old 01-10-2020, 10:51 PM
He is referring to the flaps in the VTCS system and BL is the code for second generation Mazda 3s, BK being first gen. Although I believe these names are only used in Australia.
To answer your question there isn't much you can do in terms of preventative maintenance other than remove them entirely as they're pretty much sealed inside the intake manifold. I'm pretty sure they fixed the issues causing them to fail by 2009. My 2008 2.0ls flaps had no free play and the rod was in perfect condition when removed, this was in a car with 220,000 kms so you should be fine.
Craig's video on his Ford Mondeo (I'd link the video but can't as I don't have enough posts on the forums.) showed the issue to be the small plastic inserts between the intake runners. These weren't present on my manifold so I doubt they would be on yours, I only removed my flap assemblies for the slight performance benefit which is actually quite noticeable.
But yeah you should be fine, and no, there isn't much maintenance you can do.
chayton is offline
