Need data logging info) just bought Cobb AP - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 19 (permalink) Old 08-05-2009, 04:26 PM Thread Starter
Send a message via MSN to Speed 3 Visionary
Okay i just bought myself a Cobb Ap. I can do data logging but the problem is, I dont know what numbers my car should be at (how do i find out???) Plus some of the terms in logging i am not yet familiar yet with all of them. Where is a good place to educate myself on some terms and numbers my car should be at!!! I have cobb SRI, cobb AP, hks bov, Turbo XS FMiC, and a greddy catch can so far!
Speed 3 Visionary is offline
post #2 of 19 (permalink) Old 08-05-2009, 05:42 PM
Re: Need data logging info) just bought Cobb AP
The air/fuel ratio (AFR or A/F) should taper down from ~14.7 at idle/cruising to ~11 at high RPM full throttle / full boost. The knock retard (KR) should be 0. Those are the most important things to keep tabs on.
Oh also for the MS3, your fuel pressure should not be dipping too low (i think below ~1400psi is when people start to get concerned?) at higher RPMs.
What specific terms you're seeing are you unfamiliar with, which I didn't cover here?
cali_axela is offline
post #3 of 19 (permalink) Old 08-05-2009, 06:25 PM Thread Starter
what is knock retard? i think i saw it hit 0.3 one time.
post #4 of 19 (permalink) Old 08-05-2009, 06:27 PM Thread Starter
my boost is about 16.2 psi at 5000 rpm/ at 4000 rpms fuel pressure is 1739 and at idle it's 425/ knock retard is 0.3 only one time never saw again/ AFR is 14.7 at idle and 29.3 at full throttle (the more gas i give the higher this number goes?
now for the questions??/??????????????
-what is throttle position
-fan duty
-fuel inj. amt.
*mass airflow
-calculated load
*intake temp
words with this (*) symbol i dont know what the numbers should be at... (-) this symbol i dont know the numbers and i dont know what they mean??
post #5 of 19 (permalink) Old 08-05-2009, 07:22 PM
[quote author=Speed 3 Visionary link=topic=152513.msg3265105#msg3265105 date=1249511261]
my boost is about 16.2 psi at 5000 rpm/ at 4000 rpms fuel pressure is 1739 and at idle it's 425/ knock retard is 0.3 only one time never saw again/ AFR is 14.7 at idle and 29.3 at full throttle (the more gas i give the higher this number goes? an AFR of 29.3 under boost is practically impossible without blowing your engine... it should only go that high while engine braking with no throttle input. Should go down into the 11 (or even 10) range at full throttle...
-what is throttle position how far down you're pressing the gas pedal
-fan duty how much your radiator fans are spinning
-fuel inj. amt. how much fuel your injectors are spitting
*mass airflow voltage of your MAF sensor
-calculated load ECU-calculated magic number based on all of the other sensors' readings
*intake temp this is directly related to the ambient air temp and how much heat soak you're getting
post #6 of 19 (permalink) Old 08-05-2009, 07:54 PM Thread Starter
hey cali did you write something????
post #7 of 19 (permalink) Old 08-05-2009, 08:07 PM
Everything in bold... answered inline, it was easier and more clear.
post #8 of 19 (permalink) Old 08-05-2009, 08:21 PM Thread Starter
o lol thanks... What is a knock retard? because the car just hit 0.7 now. Plus if you say my engine would blow at 29 could the ap be reading AFR wrong or is there something that i should do? What could be causing this issue of such a high AFR... do you know a link that i could educate myself more on this subject...
post #9 of 19 (permalink) Old 08-05-2009, 09:04 PM
Knock retard is when the engine backs off the ignition timing because it senses a very small amount of predetonation. It's actually very common in this car and levels that low are nothing to worry about. Do you use 91 or 93 octane? It'll happen a lot more with 91.
The AFR... well I've never used an AP so yes it's possible that either it's using different units/the ratio is backwards or something else is wrong. There are calculations that need to be done to get an AFR reading in the typical ratio format most people discuss it in from the voltages that the AP reads directly off the factory wideband sensor.
post #10 of 19 (permalink) Old 08-05-2009, 09:14 PM
Send a message via AIM to myms3
if you can post the log for download.. then some of us can take a look.
When do you see the .3 and .7 KR?
myms3 is offline
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > MazdaSpeed
