Need advice REALLY quick! - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 7 (permalink) Old 07-27-2007, 09:23 AM Thread Starter
Send a message via AIM to Truredspeed3
Ok. So I had my muffler and second resonator removed. Now, If I removed the cat from the race pipe section and the first resonator on the catback, would it make that much for of a difference in sound/performance? I need advice quick because I might go to the shop in the next hour or so! Please help!
-Chris
Selling my Mazdaspeed3.
Truredspeed3 is offline
post #2 of 7 (permalink) Old 07-27-2007, 09:25 AM
Ryz
Re: Need advice REALLY quick!
The MS CBE only has a single small muffler. I also have the XS pipe and the sound is just where I like it. I'm not sure how it would be straight from the DP. Might drone.
MazdaSpeed CAI/CBE, ETS 3.5" TMIC, TurboXS Racepipe, MAXFLOW CDFP, TRZ Delrin Rear Mount, Medieval Side Mounts, Forge BPV, TWM STS/Bushings, SU Boost Tubes, Redline Tuning QuickLIFT Elites, Shark Fin Antenna, Tint 50/20, Clear/LED Rear Reflector Replacements, Smoked LED Side Turn Signals, Blitz IV Dual Turbo Timer & Boost Gauge, V1 w/Remote Display, Removed Side Molding, Debadged, Blacked Out Rear Flying M, Redline MT-90, PP 5w-30, Child Booster Seat, 16" Konig Further w/Dunlop SP Winter Sport 3
Ryz is offline
post #3 of 7 (permalink) Old 07-27-2007, 09:27 AM Thread Starter
Nah, I wanna replace the cat in the stock "race pipe" with a straight pipe...and remove the first resonator in the cat back. So I will only have 1 cat in the DP correct?
post #4 of 7 (permalink) Old 07-27-2007, 09:30 AM
Ryz
Yes, one in the DP. But straight the rest of the way back can introduce harmonics.
Ryz is offline
post #5 of 7 (permalink) Old 07-27-2007, 09:36 AM Thread Starter
Will it be a low rumble sound? Would it drone really bad if I did this? I mean really bad drone! Because I had a 06 mx5 with a full catback and that thing dronned like a bitch!
post #6 of 7 (permalink) Old 07-27-2007, 09:38 AM
Ryz
Hard to say without actually hearing it, start with the resonator and take a listen then go for the cat. Make sure you drive it, I'm sure you've noticed that it sounds a lot different under load.
Ryz is offline
post #7 of 7 (permalink) Old 07-27-2007, 10:06 AM Thread Starter
Yeah, it sounds a bit different underload. Cruising, sounds stock..but when you get on it, it has almost a tornado like sound rushing through to the back of the car! Sound sweet!
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > MazdaSpeed
