Badge Removal? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 5 (permalink) Old 07-18-2017, 09:08 AM Thread Starter
Badge Removal?
Recently bought a 2008 Speed 3 - the rear badge looks like maybe it's been removed and then reattached at some point. Any idea what the drip residue might be and how to clean it up? I don't mind taking the badge back off - I like the clean look and nearly every other badge is already gone. Just want to clean this up without harming the paint as much as possible.
MS32008Newbie is offline
post #2 of 5 (permalink) Old 07-18-2017, 11:51 AM
Two holes located behind it so I'd leave, but pick up a Meguiar's or California gold claybar kit from Walmart and any surface contaminates will come right off. I've attached my G as a confirmation to it's effectiveness since there was 5 yr old 3M tape behind those letters.
Fujita CAI . Grounded Throttle Body . Shark Fin Antennae . Vibrant Exhaust . Vibrant Header . Spoiler . 35% Tints all around . Advanced Timing . Progress Rear Sway Bar . Cp-e Rear Engine Mount . Street Unit Side Mounts . DDM HIDS . Umnitza Chromium Angel Eyes .
mzdahalos is offline
post #3 of 5 (permalink) Old 07-31-2017, 11:08 PM
If you take your time and are really careful, it's possible to spot-fill the holes with some body filler, and then carefully blend and repaint the two spots. It'll take some patience, but I've seen people manage it with good results.
thzpcs is offline
post #4 of 5 (permalink) Old 06-23-2019, 02:10 PM
mazzdas238638's Avatar
It will take some work, but to prep it best try GooGone Remover (Yellow bottoles..) let it sit for 5 mins or so then try to buff off with fingers inwards to outwards, or soft sponge/rag and if you are comfortable with it use a orbital polisher. Re-apply more application if needed.
Some new double sided 3M tape to put badge back on may work to put it back in it's place or new spot.
to remove other emblems or stripping, i prefer to slowly and closely ridge in the edge or first letter/number with a strand or roll of "Kite" string and saw back and fourth until its off - googone will help with this process also.
Hope it goes well for you.
hope I added some input someone can use for reference.
mazzdas238638 is offline
post #5 of 5 (permalink) Old 06-23-2019, 02:18 PM
Try some black silicone sealant to fill small holes or gaps, easy fill, dry and light light sand. good to go.
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > Exterior Modifications
LinkBack to this Thread: http://www.mazda3forums.com/658-exterior-modifications/750161-badge-removal.html
Exterior Modifications [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-10-2017 06:06 AM
Timing Chain removal Ouroboros Stock Issues 4 04-09-2017 02:11 PM
Searching for an Evil M badge pat_per123 Introductions 2 12-21-2016 01:37 PM
Steering knuckle removal help JigaWatt Powertrain 2004-2009 Mazda3 3 08-26-2016 08:39 PM
2014 Door Panel Removal jmgarcia Mazda3 (Axela) 0 08-22-2016 03:39 PM
