Halogen Headbulbs Not Lighting Up - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 5 (permalink) Old 09-25-2019, 10:38 PM Thread Starter
Hey everyone,
I've been having this issue with my 2008 Mazda 3 for a while now, but now it's reached a critical point as both of my headlights (lowbeam) are not lighting up.
It used to be just my driver side headlight that did this. It would randomly not turn on, especially it seemed after heavy rain. Strangely enough, for some reason, hitting the headlight housing would turn it back on...
As time went on, this problem got worse and my "fix" had a success rate of about 50%. Then it started happening on my passenger side bulb (again, hitting it would activate it most times).
At this point neither of them work. About 10% of the time I can hit the driver side headlight and activate it.
High beams are fully functional. Any ideas on where to go from here? I'm worried to go to a mechanic and get hosed if it's a relatively cheap fix.
Spatpora is offline
post #2 of 5 (permalink) Old 09-26-2019, 06:11 AM
have you tried replacing the bulbs?
lout is offline
post #3 of 5 (permalink) Old 09-30-2019, 10:40 AM Thread Starter
I have tried, it is not the bulbs since they come on sporadically. If it was dead, it would be dead. They are not burnt out. I feel like it's some kind of grounding issue perhaps.
Spatpora is offline
post #4 of 5 (permalink) Old 10-01-2019, 02:39 AM
sometimes the little element inside the bulbs break and intermittently make contact
if you have tried new bulbs then check wiring
lout is offline
post #5 of 5 (permalink) Old 10-04-2019, 05:12 PM
Make sure the black bulb holders don't have a bunch of corrosion inside of the terminals. This is a pretty common issue.
theblooms is offline
