Xenon HID - Frequently Asked Questions - Page 20 - Mazda3 Forums : The #1 Mazda 3 Forum
post #191 of 198 (permalink) Old 11-29-2013, 07:21 AM
philrab's Avatar
Originally Posted by m1ke View Post
kinda new when it comes to lighting. I have an 09 speed 3, wanting a little more white/blue look in place of stock low beams. would Nokya Pro Halogen Headlight Bulb - Cosmic White bulb code 9005 be what im looking for? The link on SU says 2007-2010 Mazdaspeed 3: High/9005, Fog/9006/H11. does this mean it will fit my low beams too?
http://www.streetunit.com/Nokya_Pro_...e_p/nok-cw.htm
This probably isn't the best place to ask this question, and BTW posting the same question in 3 separate threads isn't helpful either.
philrab is offline
post #192 of 198 (permalink) Old 11-10-2014, 05:37 AM
liquisoLe's Avatar
I have a problem with one of the xenon light (passenger side). It doesn't always come on, often I have to turn the lights off and on again a couple of times for it to light up, and the "lights are on" -sound beeps even if the lights are off when I turn off the car and open the door.
And if I turn light back on and off again when car is off the beep stops. Guess this have to do with the one light that doesn't always light up.
The previous owner had bumped into something (small scratches on front bumper) so I guess it's maybe something loose? Ideas? :S
liquisoLe is offline
post #193 of 198 (permalink) Old 11-12-2014, 12:49 AM
I'd check for a tight,corrosion-free connection to start,and progress from there.
'06 3 S(?), stock runaround car
'12 RAM 1500 trailer tow b*tch.
'01 Sentra SE SR20DE lotsa mods.
audio1der is offline
post #194 of 198 (permalink) Old 11-12-2014, 06:59 PM
Mazda3S08's Avatar
Audio1der is on the right track, also make sure to check the bulbs are seated correctly and arent corroded inside the contacts. You may also be dealing with a bulb about to die on you. Happened to my foglights before one bulb burned out. It could also be a bad ballast try swapping ballasts and try to recreate the problem. If it fixes the problem, you will need to get an additional ballast.
Mazda3S08 is offline
post #195 of 198 (permalink) Old 11-17-2014, 05:41 PM
liquisoLe's Avatar
allright, thanks guys! will do!
post #196 of 198 (permalink) Old 01-10-2016, 08:27 AM
manu rata's Avatar
hi guys, can i replace the H7 bulb with a D2S bulb ? ( and the ballasts) or i need an adapter or something like this? And if i will do this, the D2S will be eficient into the H7 projector lens ? Thank you
Mazda 3 `07
manu rata is offline
post #197 of 198 (permalink) Old 03-15-2018, 09:09 AM
This has probably already been answered, so I apologize in advance, where can I buy the XTEC 5000K kit in the US and how much does it cost?
47r0n1n is offline
post #198 of 198 (permalink) Old 04-30-2020, 09:52 PM
Pics or it doesn't exist jk
AztecDevil is offline
