rim bore sizes - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 13 (permalink) Old 07-03-2009, 03:18 PM Thread Starter
rim bore sizes
Hi guys,
Im a new mazda owner coming from a Honda. Most honda wheels have the exact bolt pattern and offset liek mazda rims. Mazda 3 in particular. The only differance is the bore size. Mazda 3 is 67mm and Honda Prelude is 64.1mm.
My question is this. Would it be worth making the bore bigger so I can use my old honda rims for winter? or is there some sort of adapter? I know I can use a spacer to put mazda rims on a prelude, bt I want to go the other way around.
thanks everyone!
valongueiro is offline
post #2 of 13 (permalink) Old 07-03-2009, 03:20 PM
tigermack's Avatar
Re: rim bore sizes
You can bring it to a shop to have it trim out a few mm around the hub, it shouldn't damage anything if done properly...
tigermack is offline
post #3 of 13 (permalink) Old 07-03-2009, 03:21 PM Thread Starter
Re: rim bore sizes
[quote author=tigermack link=topic=149507.msg3209779#msg3209779 date=1246645206]
roughly how much...Im just wondering if im better of with a set of steelies.
post #4 of 13 (permalink) Old 07-03-2009, 03:24 PM
Re: rim bore sizes
cant put 4 lug wheels on a 5 lug...just to make sure that's not what you're trying to do. I called around to bore my IS300 wheels out and they told me 100 per wheel...maybe i called the wrong places...
__________________________________________________ _____________________
F2 CAI | Advanced Timing | Thunder Header | Magnaflow Exhaust | TB ground |Coolant Bypass | TWM SS | 20% Tint | 5000k 50W HID | Stubby | BCC | Enkei | Alternator & Water Pump Pulleys | Exedy Stage 1 Clutch and Flywheel | ARK ST-P Coilovers | VTCS | ETD |
08mazda2.0 is offline
post #5 of 13 (permalink) Old 07-03-2009, 03:35 PM Thread Starter
Re: rim bore sizes
[quote author=08mazda2.0 link=topic=149507.msg3209785#msg3209785 date=1246645459]
lol of course im using a five lug wheel.
at 100 per wheel, might as well buy steelies
post #6 of 13 (permalink) Old 07-03-2009, 05:55 PM
Re: rim bore sizes
Unless you can find a wheel place that is setup to do boring you won't get it any cheaper. At the same time you can probably get steelies for less than you will get them bored any where.
17" Motegi RT5's Flat Black | Hella 90mm 3000k HID | AWR Rear Engine Mount | 4300K HID's color and cutoff modded | AEM CAI
LED White/Amber Signals | Door Protectors Removed | Weather Tech Liners | Progess Springs | Camber Kit | Tinted Tails | Open Mouth Grilll
cy|{lopsNine is offline
post #7 of 13 (permalink) Old 07-03-2009, 06:49 PM
XB
Re: rim bore sizes
XB is offline
post #8 of 13 (permalink) Old 07-03-2009, 08:39 PM
Re: rim bore sizes
[quote author=cy|{lopsNine link=topic=149507.msg3209984#msg3209984 date=1246654500]
post #9 of 13 (permalink) Old 07-03-2009, 08:59 PM
PZ
Re: rim bore sizes
Bring it to a machine shop - a regular one, not an automotive one. I doubt it would cost much more than $100 for all four.
When you do it, bring a Mazda wheel with you so they can take an exact measurement. This way they will be able to give you exacty the right center bore.
PZ is offline
post #10 of 13 (permalink) Old 07-03-2009, 09:01 PM
Re: rim bore sizes
i called machine shops and that's what they told me some didn't even know what i was talking about. Those wheels are still sitting here till this day.
