Nitrogen Filled Vs. Regular Air Filled Tires - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 54 (permalink) Old 06-28-2006, 04:31 PM Thread Starter
Send a message via MSN to Midnight_Speeder
I got my wheel/tire setup filled with nitrogen, but I feel that the tires aren't as grippy as they should be. That leads me to believe that I should decrease the air on the tires. They are at about 32 psi right now I believe, so what should I put them up to?
If I do have to increase them, are there any effects with using the reg. air vs. the nitro. air?
Thanks,
Geoff
The Midnight Speeder
Midnight_Speeder is offline
post #2 of 54 (permalink) Old 06-28-2006, 05:42 PM
Send a message via AIM to KoRn
Re: Nitrogen Filled Vs. Regular Air Filled Tires
Im using 35psi all around. My cars have always used that. Its the sweet spot imo for tires. I dont know with your nitro though. I just use regular air.
Mazda 3i 05 Velocity Red Mods: Borla cat back exhaust, SilverStars low&high beam bulbs, Removed side moldings, Red calipers with Mazda 3 logos, 17x7 Exel P-5 gunmetal wheels, 205-50 17 Hankook Ventus Sport K104 tires, Eibach pro kit, Stubby antenna, Satin fuel door, Graphite grey metallic badges, S model taillights
KoRn is offline
post #3 of 54 (permalink) Old 06-28-2006, 05:44 PM
I am keep mine at 34-35(cold) with standard air
Brian805 is offline
post #4 of 54 (permalink) Old 06-28-2006, 10:52 PM
Banned
I usualy keep mine at 38psi front and rear filled with Premium Air!
SoraNezumi is offline
post #5 of 54 (permalink) Old 06-28-2006, 11:04 PM
pgmomni
Guest
Posts: n/a
[quote author=Midnight_Speeder link=topic=50101.msg791789#msg791789 date=1151526663]
Thanks,
Geoff
On my wifes car Costco used Nitro in her tires and I have never had to add air to them again.
Her tires now maintain a steady 32lbs for over a year now.
As far as I can tell it make sno diff on handling.
post #6 of 54 (permalink) Old 06-28-2006, 11:38 PM
Nitrogen are used in aviation to prevent corrosion on wheels since regular air will always have moisture.
zubzer0 is offline
post #7 of 54 (permalink) Old 06-28-2006, 11:51 PM
Send a message via Yahoo to onewingedangel
If I were to fill my tires with helium... will my car be faster???
:hide:
[url=
src="
border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
onewingedangel is offline
post #8 of 54 (permalink) Old 06-29-2006, 12:53 AM
Banned
I've got my tires (including the spare) filled with nitro as well. Stays a constant PSI which reduces tread wear, leaks 6x slower due to larger molecule size, and supposed to help with corrusion of aluminum wheels. Jay Leno and Nascar uses nitro so I figure its good more me. Think its more common outside of the States.
xxxxxxxxxxlc is offline
post #9 of 54 (permalink) Old 06-29-2006, 01:08 AM
Where can U get tires filled with nitrogen? How much will that cost?
island warrior is offline
post #10 of 54 (permalink) Old 06-29-2006, 05:43 AM
^ Im curious about that as well.
KoRn is offline
