Brake System Flushing Tools - Mazda3 Forums : The #1 Mazda 3 Forum
 8Likes
post #1 of 49 (permalink) Old 08-26-2018, 10:54 PM Thread Starter
VWandDodge's Avatar
I need to flush the brake system on both my Mazda and non-Mazda vehicle. I've seen references to vacuum units that operate with the aid of an air compressor; however, it looks like they're set up for European vehicles. I've been considering a pressurized unit which requires the mechanic to pressurize the unit with a hand pump before he/she drains the fluid at each wheel.
Does anyone have any experience with such units? The benefit is the ability for a single person to handle the complete changing of the fluid rather than the two-person pedal pump system. I'm certain there is a solution out there for less than $75. I do have a Mighty Vac brake bleeder, but that's not enough for performing a serious flush.
VWandDodge is offline
post #2 of 49 (permalink) Old 08-27-2018, 12:23 AM
Banned
Most cars now have ABS??? Anyone performing service work except pads and rotors and simple brake fluid replacement (master cylinder and at the calipers only) or bleeding the brakes should study how to do it (*and it is not easy for DIY). Most that think they are replacing the complete fluid are actually only only replacing most but not all the brake fluid with an ABS brake system because of the complexity of the system..
I recomend is a *complete flushing & replacement is serviced that people you use ONLY the FACTORY SERVICE MANUAL for their year and model vehicle and follow EXACTLY the procedure outlined.
When DIY or less then an experienced "mechanic" try to do service on their brakes if not done properly not only take your life into your hands if it is not done correctly but everyone else they share the road with as well!!!
M3RacerX is offline
post #3 of 49 (permalink) Old 08-27-2018, 03:56 AM
mrb
mrb's Avatar
automotive bleeder screw with a built-in check valve --- cheapest solution --- one person operation.
The fancy brake bleeding pressurized systems are handy, but expensive.
mrb is offline
post #4 of 49 (permalink) Old 08-27-2018, 12:07 PM
Datsun1600's Avatar
I've only used the vacuum method using a Mighty Vac. I wasn't all that impressed and went back to the 2-person method. My son and I can knock out a system flush in about an hour. In Colorado we have the advantage of super dry air, so brake fluid probably can last a long time, but I still like to change it every two years.
I really should buy one of those simple 'hygrometer' type testing units to measure the moisture content.
Datsun1600 is offline
post #5 of 49 (permalink) Old 08-28-2018, 01:55 AM
i use a vacuum bleeder that attaches to the bleed nipple
i first vacuum out all fluid from the master. then fill with fresh using a different brand/color to last time
then connect bleeder to bleed nipple and loosen bleed nipple
then pump pedal maybe 6 times and top up master
repeat until you see the color change in the bleeder hose
then lock nipple
using a piece of wood between seat base and brake pedal, i depress pedal then just crack bleeder to get last bit of air out
then move on to next wheel
and if anybody with abs tells me you must start with wheel furthest from master cyl i will scream as they are all separate pipes now
if i have a helper it is a lot quicker
lout is offline
post #6 of 49 (permalink) Old 08-28-2018, 09:16 AM
Banned
There is a difference between a flushing what the OP considering doing and bleeding,refill of a brake system? One is easily accomplished and can be done without the aid of special tools and diagnostic equipment. I would suggest that VWandDodge who is wanting information about "flushing" (thread title :Brake System Flushing Tools ) read up on these 2 very different methods of service on a vehicle.
M3RacerX is offline
post #7 of 49 (permalink) Old 08-28-2018, 02:01 PM
Datsun1600's Avatar
Hey, this is all I knew! If I don't have to do it in any particular order now, then that is great. I just explained this concept about starting from the furthest wheel and moving to the closest wheel to my son.
You may scream if it makes you feel better. :-)
post #8 of 49 (permalink) Old 08-28-2018, 02:18 PM
Banned
many responses are exactly why I get lots of customers with brake issues after the attempt to work on their brakes with ABC and TRAC.
M3RacerX is offline
post #9 of 49 (permalink) Old 08-28-2018, 03:56 PM
The only tools you need are a turkey baster, an 8mm flare wrench, a 10mm flare wrench, a hose clamp, some clear tubing, and an empty soda bottle with a hole drilled in the lid.
Pour some brake fluid in the soda bottle
Put the tubing down the bottle so the end is submerged in the brake fluid.
Put the flare nut wrench on the bleeder valve
Place the tubing over the bleeder valve, and use the hose clamp to tighten it down.
Pop the top off of the master cylinder
Empty as much fluid as you can with the turkey baster, and fill it with fresh fluid
Open the bleeder valve
Pump the brakes, watching the fluid come out
Keep an eye on the fluid level in the master cylinder. Keep refilling as it goes down.
When the fluid runs clear, you're done. Tighten the bleeder screw, and move on to the next wheel.
I like to start at right rear, then go left rear, then right front, finishing up at the left front.
EricTheCarGuy has an awesome video showing this process. I've done it, it really works great.
theblooms is offline
post #10 of 49 (permalink) Old 08-28-2018, 04:22 PM
Banned
The thread initial question and also a follow up that is NOT BLEEDING but "FLUSHING" . The vehicle (at least one) the OP is mentioning although he has not confirmed but may in fact have ABS brake system !!!
Many times you won't even know you did it incorrectly until the ABS activates for a panic stop and then you will know very fast that something is not working properly.
But fear not the vehicle in front of you will act as an example of Newton's ABS braking law of physics's which is that every car in front of you will remain stopped and will help you to stop your vehicle when you hit it.
I know Eric (The Car Guy) for years and often use his video's to support some of my service technical support on forums. Some may look a little more for his video information about ABS system.
A quote I found today:
The biggest challenge for those of us with partial knowledge is to know our limits.
M3RacerX is offline
More Rotor & Brake Pad Kits RockAuto RockAuto 1 11-12-2018 09:11 PM
More Fluids and Tools at RockAuto.com! RockAuto RockAuto 0 11-30-2017 03:29 PM
Brake issues, need help. Fixed (for now) magna99 Powertrain 2004-2009 Mazda3 2 08-27-2017 02:25 PM
Get guaranteed power gains with K&N 69 Typhoon Air Intake System! carid CARiD.com 0 02-03-2017 07:16 AM
