U0101 - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 4 (permalink) Old 05-28-2019, 10:15 AM Thread Starter
U0101
Hello,
I have a 2008 Mazda 3 Automatic transmission with about 135,000 miles on it. I got the U0101 code on my car after trying to leave my house the other day. I didn't really drive the car, but when parked and shifting into Drive or Reverse, it is pretty jarring and makes a loud banging sound.
I looked around here on the forums and most people with this code swap out the TCM and it seems like they get the issue fixed. Is there anything I should look at or check out before I shell out all the dough for a new TCM?
Thanks for any info!
-Andrew
misfitbum is offline
post #2 of 4 (permalink) Old 05-29-2019, 08:36 AM
I'd always do the simple and easy testing, before hanging on parts. First do a static and running test on the battery, to make sure those readings are somewhere around 12.5/13.5 volts. Then remove the TCM connector and examine both sides for corrosion or other issues, and check the wiring going into the connector as well. Reconnect the TCM and see if anything changed. If not, then disconnect the battery, touch the battery connectors together to drain the caps, and then reconnect and see if the problem goes away (even for only a short time).
m3iguy is online now
post #3 of 4 (permalink) Old 05-31-2019, 10:50 AM Thread Starter
Took everything apart, fuses and wiring look fine. Battery also tested good.
I went ahead and ordered a TCM. It should be here today, so this weekend I'll be able slap the new one on there. Fingers crossed it fixes the issue.
I'll report back once I find out. Thanks!
post #4 of 4 (permalink) Old 06-04-2019, 05:48 PM Thread Starter
The new TCM that I installed, fixed all the issues I was having.
My 3 is back to driving normally.
Glad I got it fixed!
