Car not starting - Mazda3 Forums : The #1 Mazda 3 Forum
  • 1 Post By Jchu14
post #1 of 5 (permalink) Old 05-07-2019, 02:51 PM Thread Starter
Car not starting
I originally posted this in the wrong section.
I have a 2006 2.3L w/ 91k miles. About 2 weeks ago I tried to start my car and I could hear the starter turning but the engine wouldn't start. I turned key to off and tried again and it started no problem. Ever since then the first time I try to start the car it won't kick on but the second time it always comes on. If I make a short stop and engine is still hot when I try to start it, it usually starts no problem. Sometimes on second effort to start it, it chugs a bit, struggling, but then reaches idle and sounds normal. I had battery and alternator tested and both checked good.
If it was starter, I'd think it would happen all the time or more randomly than every time I try a cold start. Possibly fuel pump losing prime? Any ideas?
jchinks is offline
post #2 of 5 (permalink) Old 05-09-2019, 09:27 PM
Have you changed your spark plugs? My previous 2004 3i was hard starting right around 90k miles, until I changed my original set. The car never misfired or else I would haves changed them earlier...
ndnationfan is offline
post #3 of 5 (permalink) Old 05-14-2019, 06:03 PM Thread Starter
I haven't changed the plugs. Will be doing that next week as I'm overdue. Would bad plugs be as regular as my symptoms are, though? Won't start on first attempt but starts second time always...
jchinks is offline
post #4 of 5 (permalink) Old 05-15-2019, 01:09 PM
Maybe it's a fuel pump issue? Your first start pressurized the fuel system enough so that it's easier to start the second time.
Do you have issues with misfires when you accelerate at full throttle or climbing a steep hill?
You can also try to prime the pump first by turning the key to 'on' (don't actually start it), wait a few seconds to let the fuel pump work, then start the car. If the car starts every time, then I'd be more confident that it's the fuel system rather than the ignition system.
lout likes this.
Jchu14 is offline
post #5 of 5 (permalink) Old 05-21-2019, 01:14 PM
Starting up the second time.. I think I've heard of this when the crankshaft position sensor is going out
Birchtree is offline
Car Having Issues Starting Sometimes..Help! ChyrsCC Maintenance and Care 11 07-29-2019 10:50 AM
AC sound when starting the ac for the first time mazdablue Mazda3 (Axela) 3 05-04-2018 12:26 AM
Problem starting my '06 MZ3, seems clutch-related allfiredup Powertrain 2004-2009 Mazda3 3 04-16-2018 09:47 PM
Problems with starting / fuses CityWheelin Mazda3 (Axela) 0 09-25-2017 12:54 PM
