Hanger bearing - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 3 (permalink) Old 04-04-2019, 07:09 PM Thread Starter
Hanger bearing
Looking for advice on my Mazda three. It's a 2008 with a manual and a 2.3. I noticed a banging last year coming from somewhere in the front end that seemed to get worse at higher speeds. Car has now been parked since the beginning of winter as I've been worried about doing damage to the trans running with a possible did hanger bearing. When I grab the CV axle where it enters the hanger there is some slop on the spline but no worse then the driver side. I can how ever move the hanger shaft back and forth in and out of the transaxle . Is this the culprit or normal?
https://vimeo.com/328540139?ref=em-share
Sent from my SM-G930W8 using Tapatalk
shelbygt660 is offline
post #2 of 3 (permalink) Old 04-06-2019, 11:07 AM Thread Starter
I'm considering pulling it out later today. Any advice if it's bad or not judging by the video?
post #3 of 3 (permalink) Old 04-10-2019, 05:14 PM
That's completely normal movement. How are your sway bar end links? When your suspension is loaded they will not appear bad. You almost have to take them off to see. They make a pretty bad banging sound when they go bad.
Xbeaus is offline
2004 2.3 S Automatic - Bad Transmission Bearing? thekingofspain Powertrain 2004-2009 Mazda3 19 06-12-2018 11:08 AM
WJB Hub, Bearing & Seal Instant Rebate at RockAuto.com! RockAuto RockAuto 0 03-09-2018 10:17 AM
Backward wheel bearing 2007mazda3 Powertrain 2004-2009 Mazda3 1 11-20-2017 06:39 PM
Loose intermediate drive shaft/carrier bearing Surfhatch Stock Issues 0 11-19-2016 12:08 AM
