06 to 04 mazda 3 2.3l wiring harness swap - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 3 (permalink) Old 01-27-2019, 05:44 PM Thread Starter
Has anyone successfully swapped the engine wiring harness from an 06 mazda 3 2.3l engine to a 2004 same engine? Im stuck trying to figure out a way to adapt the two harness plugs together. Any thoughts?
Msheph10 is offline
post #2 of 3 (permalink) Old 02-01-2019, 12:11 AM
rickkari's Avatar
One thing is for sure, the 06 uses 3 wire coils and 3 wire cam sensor. The 04 uses 2 wire for both.
Jesus Saves
rickkari is offline
post #3 of 3 (permalink) Old 02-05-2019, 04:52 PM Thread Starter
So basically I need to swap the transmission and wiring harness from the 06 into the 04 and then I would be set?
Msheph10 is offline
How To: Mazda/Ford 2.5L Swap mazdat02 Powertrain 2004-2009 Mazda3 304 11-17-2019 05:05 AM
Door wiring harness 2006 Mazda 3 Driver Side Door Jdanbankai Mazda3 (Axela) 1 09-03-2017 03:01 PM
Request - Door wiring harness photos 2004-2007 Mazda 3 Left Front seifer008 Interior Modifications 2 02-01-2017 10:39 PM
Swapping Ford Fusion/Escape 2.5L into 08 Mazda 3 2.3L chiyama Powertrain 2004-2009 Mazda3 14 09-21-2016 01:30 AM
