failing apart on outside (drive belts) cost? - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
 3Likes
post #21 of 25 (permalink) Old 02-07-2019, 02:19 AM
mrb
mrb's Avatar
Originally Posted by animescreen View Post
What do you do with that clamp on ac belt? Looks like macgyver stuff.
Is this the ac belt your talking about I took photo of my car and had to pry open a bit but I think can see if it is or not
Sent from my SM-N950U1 using Tapatalk
check youtube for that diy install.... you need to clamp the top portion with the bolt.
mrb is offline
post #22 of 25 (permalink) Old 02-07-2019, 07:58 PM
As I recall, start the belt completely installed on the A/C pulley and wedge it on the harmonic balancer pulley.
Akmnhg5A is offline
post #23 of 25 (permalink) Old 02-07-2019, 08:16 PM
mrb
mrb's Avatar
not much room for the Gen1 A/C belt install
mrb is offline
post #24 of 25 (permalink) Old 02-11-2019, 09:35 PM
kaimanson's Avatar
With the right tools you can do the struts and shocks in about 2.3 hours. Make sure you have a 5lb+ hammer to remove the strut from the hub. I did that on my wife 04 as well as on my parents 04. I went with Monroe OEspectrum. Just the struts. Buy yourself a spring compressor from harbor freight and remove the spring always with safety first. (Or just ask just ur mechanic how much he can charge u to swap struts). Regarding the valve cover it is pretty much a easy task. As well, remember to have the right tools, and a tube of permatex grey ultra gasket maker. Two spots near the timing chain need to have that. When installing it back follow the order from 1-14 to tight the bolts. See images attached.
File Type: png Screenshot_20180728-090346_1549938893175.png (622.2 KB, 7 views)
kaimanson is offline
post #25 of 25 (permalink) Old 02-11-2019, 09:39 PM
kaimanson's Avatar
And with all the money you are going to save. Get urself this tool...not bolt is going to be hard for you anymore...sore hands after doing mechanic work are going to be a thing of the past... enjoy! I bought this a few months ago to do a timing job on my Odyssey 08. $230 well spent. Save me about $700+ in labor + peace of mind that it was done the right way.
CV drive axle boot turn (left) animescreen Mazda3 (Axela) 52 02-12-2019 10:20 AM
Vibrations at idle, in drive theteju Powertrain 2004-2009 Mazda3 10 03-31-2018 11:11 PM
Why is my drive belt installation different?? KCS1964 Introductions 1 12-09-2017 11:09 AM
Loose intermediate drive shaft/carrier bearing Surfhatch Stock Issues 0 11-19-2016 12:08 AM
Drive cycle status keeps returning to "incomplete" hrothgarr Mazda3 (Axela) 1 08-23-2016 05:44 PM
