Transmission input speed sensor - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 13 (permalink) Old 01-08-2019, 11:55 PM Thread Starter
Is it possible to bench test this sensor? Transmission has been going into limp mode so I pull the sensor today and have a multimeter. I tried testing continuity/resistance and got nothing on the 3 pins. Any advice before I buy a new sensor. Thanks!
So just got this new multimeter and guess I didn’t have the right range. I am getting 29.1 for pins #1 & #2 and 7.9 for pins #1 & #3. No idea what range this sensor should be.
atticus167 is offline
post #2 of 13 (permalink) Old 01-10-2019, 06:43 PM
i got this same error code today at a red light i put it in neutral then when i put it in drive it wouldnt go above 3rd gear until i stopped (that was a lot of fun driving down the freeway in third gear). My car has 100000 miles and i changed the fluid twice before. I'm going to try changing the fluid again
2006 Mazda3 S Winning Blue Sedan AT
1992 Mercury Sable 3.8 Liter 175,000 miles R.I.P.
drinklime is offline
post #3 of 13 (permalink) Old 01-17-2019, 08:16 PM
i changed the transmission fluid and there was a ton of metal shavings in the filter according to mechanic.... will see if code returns
post #4 of 13 (permalink) Old 01-24-2019, 06:55 PM
fyi the code has not returned after changing the fluid (which was very brown and burnt). have you been able to solve the problem yet ?
post #5 of 13 (permalink) Old 01-25-2019, 12:13 AM
mrb
mrb's Avatar
The magnet in the transmission pan will have a ton more.
mrb is offline
post #6 of 13 (permalink) Old 04-19-2019, 06:07 PM
Holy crap I didn't realize I was dealing with this for 3 months....
I continued to get the P0715 code.
I decided to change the transmission mount.
The old one was not damaged, but was very stiff.
New mount has almost eliminated all vibrations in the car.
The code came back until I cleared the code with a scanner.
It's been a week and the code has not come back. This is the longest it has not come back. I think the transmission was shaking so violently that the sensor would malfunction from time to time.
post #7 of 13 (permalink) Old 04-19-2019, 10:14 PM
VWandDodge's Avatar
Wow. I think my transmission is running the same mount it had from the factory. How many miles on it? I had mine rebuilt somewhere over 150K.
VWandDodge is offline
post #8 of 13 (permalink) Old 04-21-2019, 12:11 AM
well the AT light just came on again, and new sensor just arrived, so im going to change it out. hopefully it fixes the rough shifting also
my car has 95000
post #9 of 13 (permalink) Old 04-21-2019, 08:29 AM
VWandDodge's Avatar
Keep us posted. Have you been following the transmission fluid & filter service schedule? I know that has no bearing on the sensor, but it will have an effect on the life expectancy of the transmission.
post #10 of 13 (permalink) Old 04-21-2019, 12:21 PM
pretty much, this (january 19) was at least the 3rd fluid / filter change, its always been brown/black
in 2013 i found out a mechanic accidentally drained the transmission during an oil change (wtf)
i might change the sensor tonight
P0500 Vehicle Speed Sensor for manual transmission Kizashi Powertrain 2004-2009 Mazda3 1 03-07-2018 09:11 AM
PLZ HELP -- 05 Mazda 3I - bad transmission or sensor? Sadface Introductions 0 03-19-2017 02:14 PM
