Replaced my starter slow crank/no start and no crank no start. - Page 4 - Mazda3 Forums : The #1 Mazda 3 Forum
 9Likes
post #31 of 38 (permalink) Old 02-23-2019, 11:07 AM
Super Moderator
shipo's Avatar
Fuel cleaner is a misnomer; just run it near empty and then fill up with a fresh tank, you should be good to go.
rickkari likes this.
2006 Acura TL 6-Speed Manual
shipo is offline
post #32 of 38 (permalink) Old 02-28-2019, 07:02 AM Thread Starter
kreimo16's Avatar
Ran it nearly empty, filled her 3/4th way up and she’s starting perfect.
All is well, and I’m back to Zooming around
kreimo16 is offline
post #33 of 38 (permalink) Old 02-28-2019, 09:05 AM
VWandDodge's Avatar
Drive it like ya stole it!
VWandDodge is offline
post #34 of 38 (permalink) Old 06-17-2019, 05:01 PM
Tekboy's Avatar
Excellent outcome! Yeah, these things are fun to drive when they work right.
Tekboy is offline
post #35 of 38 (permalink) Old 11-06-2019, 03:37 PM
ActionClaw's Avatar
Starter problems/Difficulty REMOVING starter?
This isn't going to help the OP but for others experiencing the same in the future...
I had nearly the identical symptoms at first, went through all the same battery testing, charging, replacing nonsense. Coincidentally, I'm also in Northern Ohio.
For me the problem turned out to be the short cable running from the solenoid to the starter. It was corroded until only a few strands still made a connection, unable to handle the load, until the last strand went. Maybe I'm also having the problem mentioned in the Tech Service Bulletin and its merely a coincidence that I found this while exploring.
I haven't finished yet.
I did learn that these wires rotting out on Mazda 3s seems to be a common issue so something for you to keep in mind and look out for.
Did any of you that replaced the starter motor have difficulty removing it?
I'm trying to replace mine ( on a 2004 Mazda 3, 2.3 liter, automatic).
I do not have a (Mazda, Chiltons,etc) shop manual. I found at least one suggestion online to address it from above after removing the air box, etc.
but, so far I've been approaching it only from below.
The previous owner removed and did not replace the plastic splash guard/kick plate causing corrosion underneath. This should be a super simple job but so far I haven't been able to get past the first nut.
I've applied penetrating oil more than a dozen times, used sockets, wrenches til the points got too rounded, then tried extractor sockets (resisting as long as I could but, eventually,) even resorting to vice grips but all to no avail.
*top bolt wasn’t stripped, they were just dumb and couldn’t get it to screw in*
OP kreimo16,
What did you mean? Wondering if I may be doing the same dumb thing?
Is there anything I could possibly be overlooking?
..or is this just a particularly stubborn nut?
The only other thing that I can think of left to try is putting a torch to it which I'm a little reluctant to do. Could it make things even worse possibly causing irreparable damage the stud?
Plus, considering how difficult this one is, I have no reason to believe the second nut --that I won't be able to see and barely be able to access -- won't be as bad.
I try to do things correctly, already have the new starter and got it at a good price but I'm growing tempted to just try replacing that wire with the starter still mounted ..even if to drive it to a garage but then, once there, what would/could they do that I'm not?
Has anyone here experienced anything similar with replacing their starter? Any helpful insight, suggestions, etc are appreciated.
Thanks
ActionClaw is offline
post #36 of 38 (permalink) Old 11-20-2019, 07:47 AM
VWandDodge's Avatar
This has been an interesting thread. I'm curious how long a Gen 1 starter will last before it needs to be rebuilt. So far, the starter on my car has 179K on it and is still going strong.
post #37 of 38 (permalink) Old 11-20-2019, 08:45 AM
Super Moderator
shipo's Avatar
I don't know for sure which starter is used in the Mazda3, but as a general statement, starters like the Denso units which have been on the market since at least the 1990s, last a heck of a long time. I've driven each of my last six cars to well over 200,000 miles* and only had to replace a single starter (the starter was still good but the contacts had carboned up).
* Almost true, my TL only has a little over 160,000 miles, but given how strong the starter is, I have little doubt it will last until the 200,000 mile mark as well.
shipo is offline
post #38 of 38 (permalink) Old 11-20-2019, 06:42 PM
VWandDodge's Avatar
My 1997 Dodge Ram had a Denso unit. It started going out around the 150K mile mark. I dismantled it, cleaned it, regreased it, and replaced the contacts with some seriously beefy units. I'm betting the guy I sold it to (after the truck was totaled by a tornado) will get 20+ years out of that thing.
questions on crank pulley - no start P0335 Jacob Manley Powertrain 2004-2009 Mazda3 7 07-31-2018 05:57 PM
2007 Mazda 3 OEM Remote start stopped working, immobilizer problem johnnyh55 Technical Information, FAQ's, How-To's 1 01-12-2018 01:05 PM
Crank, No Start 06OHIO3 Stock Issues 8 09-07-2016 08:47 PM
