Replaced my starter slow crank/no start and no crank no start. - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
 9Likes
post #21 of 38 (permalink) Old 02-14-2019, 05:13 PM
Um, there are only two wires going to the starter and its impossible to confuse one with the other, you don't need a diagram.
post #22 of 38 (permalink) Old 02-14-2019, 10:10 PM
rickkari's Avatar
Originally Posted by kreimo16 View Post
Anyone have the starter wiring diagram
Hope you can read it.
Jesus Saves
rickkari is offline
post #23 of 38 (permalink) Old 02-19-2019, 05:32 PM
Super Moderator
shipo's Avatar
Any updates on the issue or does the car still not start?
2006 Acura TL 6-Speed Manual
shipo is online now
post #24 of 38 (permalink) Old 02-19-2019, 09:46 PM Thread Starter
kreimo16's Avatar
Found my loose wire(white connector) . It was loose and as I was fidgeting with it it came right off, inside of the connector looked damaged ,I don’t know a better term to use other then that. It slid right back on.
Also found this service bulletin.
https://www.mazda3club.com/attachmen...-01-037-08.pdf
File Type: jpg 758BDCBA-C672-4969-94E0-AED35317A1F0_1550627048261.jpg (27.5 KB, 16 views)
File Type: jpg 5B1B2E9C-D1E5-486E-AFBB-91C1C8069126_1550627141139.jpg (23.2 KB, 14 views)
theblooms and rickkari like this.
kreimo16 is offline
post #25 of 38 (permalink) Old 02-20-2019, 12:51 PM
Same thing happened to my 08 recently. took the connector off that it shows in the bulletin and cleaned it up. No issues after that. I did not splice on the cord short but it's a cheap part to get if you need it. Around $20 or so.
Xbeaus is offline
post #26 of 38 (permalink) Old 02-20-2019, 01:32 PM
I'm glad you found the issue. I knew it had to be something simple like that.
Or get a package of shielded female spade terminals for under $5 and crimp one on.
Xbeaus likes this.
post #27 of 38 (permalink) Old 02-20-2019, 07:08 PM Thread Starter
kreimo16's Avatar
Man at autozone set me up with a these. I’ll post an update in a few days. NE Ohio just dumped 3 inches on us 😂
File Type: jpeg 5A839D31-093E-435F-9F37-478956681F2C_1550704054464.jpeg (240.0 KB, 14 views)
kreimo16 is offline
post #28 of 38 (permalink) Old 02-20-2019, 07:50 PM
Man at autozone set me up with a these. Iíll post an update in a few days. NE Ohio just dumped 3 inches on us 😂
Nice, those are the really good ones. You crimp them on and then heat the whole connector up with a heat gun or micro torch until the solder inside melts, giving you a connector that is both soldered and sealed from weather.
post #29 of 38 (permalink) Old 02-21-2019, 06:03 PM Thread Starter
kreimo16's Avatar
Update:
It started up, drove her around for about 15 miles, turned it off and on various times though the 15 miles, no issue any time. I’ll check back in within the next few days.
VWandDodge and rickkari like this.
kreimo16 is offline
post #30 of 38 (permalink) Old 02-23-2019, 11:13 AM Thread Starter
kreimo16's Avatar
Started all yesterday, will say it kinda puttered like it was clogged last night. Thinking the gas I had sitting in it for the last 3ish months might be junk. Gonna run it empty and put a fuel cleaner in it.
kreimo16 is offline
questions on crank pulley - no start P0335 Jacob Manley Powertrain 2004-2009 Mazda3 7 07-31-2018 06:57 PM
2007 Mazda 3 OEM Remote start stopped working, immobilizer problem johnnyh55 Technical Information, FAQ's, How-To's 1 01-12-2018 02:05 PM
Crank, No Start 06OHIO3 Stock Issues 8 09-07-2016 09:47 PM
