Shaking and vibes at 1500 RPM - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
post #21 of 35 (permalink) Old 01-09-2019, 10:05 AM Thread Starter
Originally Posted by VWandDodge View Post
If you've never replaced the O2 sensors and your vehicle has over 75K miles, I'd say it's safe to go ahead and replace them anyway.
Are you getting any codes?
@VWandDodge
My Mazda3 has around 130,000 miles. So I guess I could swap out the O2 sensors. Any recommendation on brand? NTK or Denso?
Yes I did get a fault code about a week ago. It was a P2187 fault code and I had a P2187 pending code as well. P2187 is "system too lean at idle (bank 1)".
I checked for vacuum leaks but the only thing that looked suspect to me was my MAF o-ring was a bit stretched out. I've ordered a new one and will get it installed once I get it in hand.
misfitbum is offline
post #22 of 35 (permalink) Old 01-10-2019, 11:22 PM
rickkari's Avatar
Originally Posted by misfitbum View Post
Would a video of the issue help?
I'm pretty sure the shaking and vibration is loud enough to be picked up on cell phone video.
I will try and take one in the next day or so.
A video would be great. It sounds like you have a mis-fire. The first possible cause listed out of the many listed in the service manual for a P2187 is mis-fire. Wonder if you have a bad coil or plug? That would account for the vibration as the vehicle is only running on 3 cylinders.
Also, the number one repair listed under the real fixes tab on Mitchell Prodemand is a bad canister purge valve/solenoid.
Jesus Saves
rickkari is offline
post #23 of 35 (permalink) Old 01-12-2019, 10:25 AM
VWandDodge's Avatar
@VWandDodge
According to RockAuto, Denso is the OE part number, so I'd stick with them. I don't think NTK would be an issue as it's a reliable brand. Over in the Dodge Ram world, the Second Gen Magnum engines only played nice with OE NTK O2 sensors .
VWandDodge is offline
post #24 of 35 (permalink) Old 01-13-2019, 11:42 PM Thread Starter
@rickkari
Here is the link to video: https://youtu.be/Qag2X9ePcZE
This weekend I hooked a spark plug tester up to each cylinder and tested them while idling and also revving in park. Nothing really looked out of the ordinary, so if I do have a misfire then it's happening in gear at that certain rpm under load. Hope the video helps to figure out what this is!
post #25 of 35 (permalink) Old 01-14-2019, 07:13 PM
VWandDodge's Avatar
Are you certain you don't have worn tie rod ends, worn ball joints, or bad bushings?
post #26 of 35 (permalink) Old 01-14-2019, 10:49 PM Thread Starter
@VWandDodge
I'm not 100% certain, but I hadn't really considered that due to the fact that the car feels fine suspension and steering wise. No knocks, creaks, rattles or etc. Just the unexplained vibration at that specific RPM.
But I can definitely check things out! I'll jack it up and wiggle on the tires and see if there's any play and also visually take a look at the tie rods and control arms.
post #27 of 35 (permalink) Old 01-17-2019, 11:04 AM Thread Starter
Last night I got the replacement MAF o-ring in the mail and installed it. The old one was pretty stretched out and didn't seem like it was sealing very good. The new o-ring did help out a small bit. It's marginal, but I do feel a difference in idle and throttle response. But the major vibration that occurs in 5th gear around 1500RPM, while cruising along at 40mph, is still there. It's really like the engine is chugging or dropping out for some reason. Low fuel, low air, I don't know. Feels starved at that specific RPM or speed.
Beginning to think that maybe the issue is the product of several things: lazy o2 sensors, worn out throttle body, clogged EGR, etc. Seems like I have several options to try, but I just hate to throw parts and money at it and hope it fixes it.
Once the cold weather breaks in the next few days, I will try to get under the car and inspect tie rods, control arms, and CV joints.
One way or another I'm gonna figure this out!!!
post #28 of 35 (permalink) Old 01-17-2019, 06:00 PM
VWandDodge's Avatar
Interesting, and makes complete sense. The emissions system can create a lot of whacky conditions like you've noted when it's compromised. Please keep us posted with your progress. You're definitely not throwing parts at it at this point. More like correcting issues and addressing maintenance items you didn't know mattered.
post #29 of 35 (permalink) Old 02-02-2019, 05:50 PM Thread Starter
So update on the shaking/vibration issue.
I swapped out the O2 sensors and put on a brand new OEM throttle body I was able to get a good price. I had planned to replace the EGR valve, but one of the bolts holding it on was just way too hard to get to and I didn't feel like dumping a lot of my coolant out as it helps to pull a big radiator hose thats in the way.
The result was: not much difference or improvement. My car does idle really good, but the vibration/shaking/shudder remains when I reach cruising speed on city streets (40-45 MPH). Not sure how to describe it any better. It's mainly occurring when my foot is keeping a steady and light pressure on the gas pedal. RPMS will be fine and constant, then they drop a bit and the car starts vibrating/shaking and kind of feels like its bogging down. If I let off the gas or goose the gas pedal, it goes away.
I'm thinking now that my best bet is to take it in somewhere and get the coils/plugs and injectors professionally tested. Maybe there's a way I get the fuel pump and fuel filter tested too?
Let me know if there is anything else to try! I just want my car to drive normal again!
post #30 of 35 (permalink) Old 02-02-2019, 10:47 PM
VWandDodge's Avatar
I'm wondering if there is a cracked/broken vacuum line. The fuel pump and filter are a one-piece setup that delivers constant pressure. I don't see that being an issue.
