Shaking and vibes at 1500 RPM - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 35 (permalink) Old 12-20-2018, 10:30 PM
rickkari's Avatar
Originally Posted by misfitbum View Post
I'm pretty sure it's the whole car. When the shaking is happening, I can't see out of the side view mirrors or the rear view mirror. The dash vibrates too. It can be a pretty intense shaking feeling, but like I said if I let off the gas pedal or get out of that specific RPM range it immediately goes away.
Various possibilities.
One thing that stands out with this symptom description is bad inner cv joints. I've seen it multiple times on many different makes and models with this symptom and it was a bad or both bad inner cv joints. The telltale sign on most is leaking grease evident from the inner boots, usually slowly over a long period of time. The loss of grease eventually causes damaging wear in the joint that shows itself on acceleration only, not cruising or coasting, but acceleration or a constant higher than normal torque like maintaining speed up a long interstate grade. Just a thought.
Jesus Saves
rickkari is offline
post #12 of 35 (permalink) Old 01-02-2019, 10:53 PM Thread Starter
So over the holidays I did get a check engine light. I hooked a code reader up and got a P2187 fault code and P2187 pending code. P2187 is "system too lean at idle (bank 1)".
Sounds like a lot of things can cause this.....vacuum leak, purge solenoid valve, MAF, O2 sensor, etc.
Could this check engine light be related to why car is running horrible and shaking like its about to fall apart?
misfitbum is offline
post #13 of 35 (permalink) Old 01-03-2019, 09:54 AM
One thing to keep in mind about many codes is that the ECM will require a certain number of reps to occur or time to elapse, before setting the code and turning on the MIL. So it's very possible the pending code is being set repeatedly, whenever the lean condition occurs at that specific RPM. However, because the MIL is not on, you're not aware that's happening. And the pending code doesn't become an actual code, because the lean condition goes away when the RPMs change, and the computer can then erase the pending code from memory. One would think there should be code to recognize the repeating problem condition, but it's also easy to understand how the engineers can't program for every possible issue that might come up.
So I think the answer to your question is very likely yes. Hopefully it won't be too difficult to locate the source of the unmetered air, now that you know what you're looking for.
2011 3i 2.0 A/T 145K miles
m3iguy is offline
post #14 of 35 (permalink) Old 01-03-2019, 11:06 AM Thread Starter
With the current symptoms of my car and this code popping up, is there a most likely culprit here?
I'm thinking vacuum leak due to the age of my car. O2 sensors are a maybe due to age as well, but I might do those as a last resort since they can be costly.
I've seen stuff that says this code may be caused by ignition misfire. I guess a bad coil is a maybe as well due to the car's age.
Faulty fuel injectors and bad fuel pressure are also possible culprits too.
I don't think it is Purge Solenoid Valve, since I replaced it maybe 30K-40K miles ago and my car starts up fine after filling the gas tank.
I guess I could clean the MAF and the Throttle Body and see if that helps with anything too. It's been bitterly cold lately, but it's supposed to be nice this weekend so I will take a look then.
post #15 of 35 (permalink) Old 01-03-2019, 11:52 AM
Here's one good write up on finding vacuum leaks, but you can find many other similar ones as well. I particularly like what they say about safety precautions, because that is really the most important thing IMO. I'd prefer to test using the vacuum gauge before getting into spraying the carb cleaner, but that's a minor consideration, and not meant to be critical of what they've presented.
https://www.2carpros.com/articles/ho...e-vacuum-gauge
m3iguy is offline
post #16 of 35 (permalink) Old 01-05-2019, 07:27 PM Thread Starter
Sprayed every hose I could today with carb cleaner. Engine never revved up though. Inspected all hoses for cracks and holes too.....so I guess no vacuum leaks?
I cleaned the MAF and throttle body plate also. No change in the problem. It's still there. I did notice the gasket on the MAF was a bit stretched out though. So I'm going to try to get a replacement of one of those.
Any other ideas?
I'm going to borrow a more robust ODB2 scanner from a friend tonight and hook it up and see if it gives me anymore info or leads.
post #17 of 35 (permalink) Old 01-05-2019, 08:16 PM
VWandDodge's Avatar
Just FYI: The O2 sensors should be replaced about every 75K miles regardless of throwing a code or not. They degrade in performance over time, so replacing them helps keep the emissions system in peak operating condition. O2 sensors which operate at peak efficiency ensure the catalytic converter will never have to be replaced (which it shouldn't unless there was a manufacturing defect).
A misfire could be due to worn insulation at the coil pack harness; a cracked coil pack; bad valve; or, a bad spark plug.
VWandDodge is offline
post #18 of 35 (permalink) Old 01-07-2019, 12:05 PM Thread Starter
I'm now getting a bit of vibration and shudder when I first accelerate from a stop. The shaking isn't as bad as it is around the 1500 RPM mark, but it's there and it didn't used to do that.
Is there a way to test the O2 sensors, before shelling out the cash to get new ones? I heard of people unplugging the sensors and seeing if that improves issues or makes them worse.
post #19 of 35 (permalink) Old 01-08-2019, 01:42 PM Thread Starter
Would a video of the issue help?
I'm pretty sure the shaking and vibration is loud enough to be picked up on cell phone video.
I will try and take one in the next day or so.
post #20 of 35 (permalink) Old 01-08-2019, 07:10 PM
VWandDodge's Avatar
If you've never replaced the O2 sensors and your vehicle has over 75K miles, I'd say it's safe to go ahead and replace them anyway.
Are you getting any codes?
