questions on crank pulley - no start P0335 - Mazda3 Forums : The #1 Mazda 3 Forum
 2Likes
  • 1 Post By Datsun1600
post #1 of 8 (permalink) Old 07-29-2018, 03:47 AM Thread Starter
Unhappy questions on crank pulley - no start P0335
I recently purchased a 2006 Mazda 3 2.3 (manual trans) that had a motor swap done before I bought it. It idled perfect but severely lacked power at higher RPMS so I suspected the timing was off and wanted to verify. I ordered a new crankshaft pulley, washers and a bolt just to make sure things were good. The new pulley I received for a (2006 2.3 Mazda 3) looked different from the one that was installed so I figured that was my problem right there... I removed the old pulley, timed everything and installed the new pulley which seemed to be the one I needed as it was lined up with the 9th tooth on my crankshaft sensor. Hooked everything back up and now the car wont start, P0335 and no spark. Both sensors are brand new, cam and crankshaft.. I even swapped out the old ones just to see as they were working before the changes. So I'm guessing maybe this isn't an 06 motor after all? any way to tell for sure?
The original pulley I removed is the first uploaded image and it has multiple gaps in the teeth, the new pulley (second upload) only has 1 single gap and is supposed to be the correct one for my year according to the parts store.. hoping for some insight from the mazda gurus here. Thanks!
Car was also throwing P0016 (correlation between cam/crank sensors) before I began which is why I replaced both sensors and started digging deeper.
Last edited by Jacob Manley; 07-29-2018 at 04:01 AM. Reason: adding additional information
Jacob Manley is offline
post #2 of 8 (permalink) Old 07-29-2018, 10:17 AM
Datsun1600's Avatar
Your old one is correct for the 2.3L 2006 Mazda 3. See this page from Happy Wrenching on a Mazda 3 engine swap which details the crankshaft pulley differences.
2006 Mazda 3 - 2.5L Ford Fusion Engine Swap Crankshaft Pulley/Damper Trigger Pulse Wheel Modification
Can you provide the part number for the new pulley? Where did you source it from?
Jacob Manley likes this.
Datsun1600 is offline
post #3 of 8 (permalink) Old 07-29-2018, 12:36 PM Thread Starter
Hey Datsun1600, thanks for the reply. I picked up the new pulley from Oreily's part number (PB1387N) apparently this is the same part number for 2.0/2.3 according to them. I guess today I have the joy of swapping pulleys again haha, thanks for the info!
post #4 of 8 (permalink) Old 07-29-2018, 12:51 PM Thread Starter
It just confused me because if you do any youtube searching for timing an 06-2.3 none of their pulleys resembled mine but all matched this newer one.
post #5 of 8 (permalink) Old 07-29-2018, 04:57 PM Thread Starter
Installed the old crankshaft pulley and timed everything, also left the new sensors in and it fires right up. Idle is great and its driving better than it ever has. Thanks for the help! Only strange part was with all the timing tools in and 8mm bolt in the pulley it puts the 5th tooth right in the middle of the sensor instead of the 4th, not sure why.
post #6 of 8 (permalink) Old 07-29-2018, 10:02 PM
Datsun1600's Avatar
It's supposed to be the 5th tooth. Glad to see that your car is up and running after putting in the original crankshaft pulley! Enjoy your car with the new engine.
post #7 of 8 (permalink) Old 07-30-2018, 10:33 PM
rickkari's Avatar
Wonder why the guy in the link didn't just install the '06 2.3 pulley on the 2.5 Fusion engine? Looks like a lot of work. Maybe it was defective.
Jesus Saves
rickkari is offline
post #8 of 8 (permalink) Old 07-31-2018, 05:57 PM
Datsun1600's Avatar
Above is the main page that I should have added as another link. The owner wanted to use the Ford timing cover and serpentine belt setup. This means he didn't need the Mazda crank pulley with an "extra" track for the A/C belt.
So, no stretch-to-fit A/C belt, and just one long serpentine belt with a tensioner. I mean, that's nice and all, but you end up relocating both the alternator and the A/C compressor. I wanted my engine to still look like a stock Mazda engine, so I just basically used the long block.
It also allowed him to use the Ford oil pan with its extra capacity.
edit: This particular web page was created by Tripwire.
Last edited by Datsun1600; 07-31-2018 at 06:01 PM. Reason: Added author of website
P0335 - Crank sensor on 2005? eatsushi Stock Issues 6 04-26-2018 11:26 PM
Very complex problem - Anti-theft car won't start Merlin123 Mazda3 (Axela) 6 01-20-2018 09:23 PM
2007 Mazda 3 OEM Remote start stopped working, immobilizer problem johnnyh55 Technical Information, FAQ's, How-To's 1 01-12-2018 01:05 PM
Crank, No Start 06OHIO3 Stock Issues 8 09-07-2016 08:47 PM
Three Month Update: 2.3 to 2.5 Swap Turd_Ferguson Powertrain 2004-2009 Mazda3 32 08-20-2016 11:14 AM
