Airbag Warning Light on- Any tips? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 6 (permalink) Old 05-26-2017, 06:46 PM Thread Starter
subjectnate's Avatar
So I've had my airbag light on for a while, and my inspection ran out. Of course it won't pass with the light on, and I would rather not pay the diagnostic fee at the dealership to see whats wrong. Are there common issues I can try out? I have been having issue with the seatbelt sensor going off randomly even though Im buckled. Maybe a seat sensor? I haven no knowledge on this.
Thanks in advance!
EDIT:
Problem has been solved. Seat belt pre-tensioner went bad, getting it fixed this Wednesday!
subjectnate is offline
post #2 of 6 (permalink) Old 05-26-2017, 09:17 PM
GerryBuc's Avatar
Probably a code that needs to be read.
Sent from my SAMSUNG-SM-G891A using Tapatalk
GerryBuc is offline
post #3 of 6 (permalink) Old 06-01-2017, 01:18 AM
I'd highly recommend checking the codes it's throwing, and get that fixed ASAP. Airbag issues aren't something to mess around with.
thzpcs is offline
post #4 of 6 (permalink) Old 11-23-2018, 03:54 AM
Hello everyone.
I noticed that the airbag light in the instrument cluster recently came on in my 2008 Mazda3 5-door. It came on the day after I spent two hours replacing my cabin air filter. Thinking back, in order to get under the dashboard I was laying on the passenger seat at odd angle and I think I may have dislodged or damaged the seat weight sensor. I've noticed that the passenger occupancy warning light above the ashtray no longer comes on at all whether someone's in the seat or not.
is it possible to remove the fabric from the seats, and then inspect or adjust or replace the seat occupancy sensor? Or is that a lost cause? I've noticed that if I squeeze and pinch the fabric above where the sensor is located,and move the sensor around, the light will go off for a few hours until someone sits in the seat again.if it's not possible to access the sensor, I guess my options are buying an emulator or replacing the seat entirely.
what do you think? Is it stupid to even try? Should I just spring for the emulator? I really appreciate any advice you can offer. Thanks everybody.
ContentCreator is offline
post #5 of 6 (permalink) Old 11-23-2018, 08:38 PM
take the seat out of car and see what you can accomplish from underneath
dont use an emmulator
if you have an accident and the passenger is hurt because the airbag doesnt go off.........
lout is offline
post #6 of 6 (permalink) Old 11-24-2018, 12:16 AM
Will do. Thank you.
LinkBack to this Thread: http://www.mazda3forums.com/61-powertrain-2004-2009-mazda3/747921-airbag-warning-light-any-tips.html
Powertrain 2004-2009 Mazda3 [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-07-2017 02:40 PM
Airbag Warning Light on- Any tips? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-26-2017 08:39 PM
Airbag Warning Light on- Any tips? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-26-2017 08:36 PM
General info and troubleshooting-Pass Airbag Off light Vic325 2004-2009 Electronics Discussion 2 04-10-2017 08:01 AM
Good Ole cel and at light please help! Dimedout Stock Issues 2 03-15-2017 11:39 PM
2006 mazda3 abs light on tomlbby Mazda3 (Axela) 3 11-28-2016 12:31 AM
Airbag control modul stefansorin21 Introductions 0 11-14-2016 02:18 PM
