Swapping Ford Fusion/Escape 2.5L into 08 Mazda 3 2.3L - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 15 (permalink) Old 09-18-2016, 11:11 PM
Originally Posted by madmatt2024 View Post
No junkyard is going to let you do all of that. Most yards drain all fluids after their evaluation and then either dismantle the car or put it in the yard. At best you will get to hear/see it run for a minute or less. Most offer a warranty on their parts though.
True. However, there's other sources other than junkyards. If, it's being sold by a private owner wrecked (Craigslist) or as insurance owned salvage.. should be able to test it thoroughly.
Turd_Ferguson is offline
post #12 of 15 (permalink) Old 09-19-2016, 12:04 AM
Originally Posted by Turd_Ferguson View Post
If, the OP's cylinder head is cracked, warped or has bad valves then that's another $150 minimum (clean, resurface, inspect at machine shop). Plus, labor for head install as well as engine rebuild which would end up being over $2000.
Didn`t say it was the cheapest option, just said it`s what I`d do were I in the same boat.
And FWIW, there shouldn`t be any extra labor to install a different head. It`s gotta come off for the rebuild anyway.
I`m sure there are pros and cons for every option.
VoodooJef is offline
post #13 of 15 (permalink) Old 09-19-2016, 12:57 AM
Yes. Replacing with another used 2.3L is the least desireable due to their price and possible oil consumption issues. Six months ago I recieved a quote from from a local machine shop to rebuilld a 2.3 and he quoted: starting at $2500.
post #14 of 15 (permalink) Old 09-21-2016, 02:14 AM
Glad I could help you with my intake adapter plate kit with your engine swap and answer all your ?'s. Looks like you snapped up a 31K engine nice score. 31K engine I would change nothing on her just pull plugs to check them out give them a cleaning and drop right back in. Make sure you are versed in the Mazda/Ford engine parts that need to be swapped. Good luck with her. Frank
2008Milan is offline
post #15 of 15 (permalink) Old 09-21-2016, 02:30 AM Thread Starter
Does the Ford 2.5L use the same plugs as the 08 Mazda 3 2.3? I just replaced the plugs with NGK Laser Iridiums about 10K miles ago. They still have plenty of life left.
I'm having a shop do the swap, I've been working closely with them and also provided printouts of two guides from the forums here for them to reference. I hope everything goes well!
Edit: Just realized that the guides say the Ford plugs are a little longer. Looks like I'll be using the Ford plugs.
chiyama is offline
LinkBack to this Thread: http://www.mazda3forums.com/61-powertrain-2004-2009-mazda3/719570-swapping-ford-fusion-escape-2-5l-into-08-mazda-3-2-3l.html
Powertrain 2004-2009 Mazda3 [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-07-2017 09:34 PM
FREE 2.3L to 2.5L intake adapter kit FREE 2008Milan Powertrain 2004-2009 Mazda3 3 09-09-2016 10:51 PM
DIY - 2005 Mazda 3 2.3L Hatchback Fuel Pump Replacement Videos DanHas3 Powertrain 2004-2009 Mazda3 2 09-07-2016 10:58 PM
