Check Engine Light and AT light : U0101 TCM issue - Mazda3 Forums : The #1 Mazda 3 Forum
 7Likes
post #1 of 23 (permalink) Old 11-07-2015, 06:42 PM Thread Starter
Welp I knew it was coming as I read about it before. Happened to my wife today while she was out.
Car jerked when shifting into reverse and drive. Would rev up and slowly take off. From what I read it defaults to 3rd gear.
Drove 55 all the way home on the interstate for 15 miles. Checked the codes with my scanner. It shows U0101 which is " failed to communicate with TCM "
I took off the TCM which resides underneath the battery tray and attached to the transmission. Pins look clean and so does the connector. Apparently these heat up plus the added heat of transmission makes them go out.
Ive checked my local salvage yards and craigslist to see if anyone is parting one out. No luck.
There is a Ebay vendor that will repair this one or send you one of theirs for about halkf the cost of new with 1 year warranty. Good reviews.
Just wondering which route to take?
rafiknj likes this.
atxjax is offline
post #2 of 23 (permalink) Old 11-08-2015, 03:44 PM
I had mine changed out a few months ago and it sure felt like it was expensive (~$600) from amazon for a little palm sized computer! I think a repaired one is fine. I wish I had that option a few months ago. Good luck.
Hookncan41 likes this.
Jchu14 is offline
post #3 of 23 (permalink) Old 11-08-2015, 04:14 PM Thread Starter
Thanks. The repaired / exchanged one from Ebay will be right at $325 with next day shipping. Im still holding out until tomorrow mid day to see if I can find one locally at the salvage yards. Only thing is that the part numbers need to match exactly.
atxjax is offline
post #4 of 23 (permalink) Old 11-09-2015, 06:11 PM Thread Starter
Update 11/9/15
Couldnt find one locally since most the salvage yards were too damn lazy to physically go out and see if they had the module I needed. So I purchased a refurbished one from a vendor on ebay. Goes by the name modulerepair.
It wound up costime $325 with express shipping. Plus a $100 core charge w hich I get back once my old one is shipped to them
Talked to the gentleman and he suggested to move the module away from the transmission by using zip ties and mounting on the firewall. Im going to fab up a aluminum bracket and mount it away from the transmission. Into more of open air. Its the heat that kills these things over time.
Once I get it back I will report on if my car works or not plus what I did to relocate the module.
rafiknj likes this.
atxjax is offline
post #5 of 23 (permalink) Old 11-12-2015, 08:45 PM Thread Starter
Got module in . Car is back up and running. Mounted the module on the brake lines on the firewall. Used a piece of rubber on the backside to assure the lines wont be rubbed through. Reason I did this is because it is the heat of the transmission that kills these modules. Car ran 20 miles so far with no issues t all.
rafiknj likes this.
atxjax is offline
post #6 of 23 (permalink) Old 02-03-2016, 05:52 AM
andrew625's Avatar
@atxjax , OP glad you were able to fix that! How has it been since?? I'm currently experiencing exactly the same issue with the same code. I've looked up the same repairer on eBay, I'll be taking my TCM out tomorrow and take a look of the number. REALLY hoping replacing the TCM will get her back running. Thank you for updating your result!!
[LIFE.LOVE.MUSIC]
3 of the greatest gifts from the Creator
andrew625 is offline
post #7 of 23 (permalink) Old 02-04-2016, 06:34 AM Thread Starter
All has been good. No issues whatsoever since I had it replaced and relocated the module on the firewall instead of on top of the hot transmission.
atxjax is offline
post #8 of 23 (permalink) Old 02-07-2016, 10:50 PM
andrew625's Avatar
That is wonderful news! One last question, I found the same eBay seller modulerepair and they still have remanufactured TCM in stock. The only thing is what they offer is a L34T and mine was a L32E (L32E-18-9E1B is the whole number, I assume yours was very close to mine if not the same). The seller said "Originally L32E is not compatible with L34T, but our TCM's are adapted to fit all the vehicles listed and all the part numbers mentioned." I was wondering if you got a L34T as well.
Thanks again for your reply atxjax!
Cheers!
[LIFE.LOVE.MUSIC]
post #9 of 23 (permalink) Old 02-10-2016, 08:00 PM
andrew625's Avatar
Nevermind, I just got the part from modulerepair and installed it. Works like a charm. Nothing feels better than getting your broken car back on the road!
Thanks OP for sharing your story and experience.
I did the same thing you suggested and tied the TCM on the brake lines.
calgarymazda3 likes this.
[LIFE.LOVE.MUSIC]
post #10 of 23 (permalink) Old 03-06-2017, 01:56 PM
Having same problem, found this thread, just wanted to check:
is it still working?
thanks!
cmuhrig likes this.
harryspider is offline
LinkBack to this Thread: http://www.mazda3forums.com/61-powertrain-2004-2009-mazda3/694033-check-engine-light-light-u0101-tcm-issue.html
Check Engine Light and AT light : U0101 TCM issue - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-08-2018 03:27 PM
Check Engine Light and AT light : U0101 TCM issue - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-27-2017 05:16 AM
Check Engine Light and AT light : U0101 TCM issue - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-26-2017 08:39 PM
Check Engine Light and AT light : U0101 TCM issue - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-26-2017 08:36 PM
Thread Check Engine Light and AT light : U0101 TCM issue | FMVperformance.com : The site for all your Ford Mazda and Volvo needs | BoardReader This thread Refback 04-29-2016 12:09 AM
FMVPerformance.com Network: The sites for all your Ford Mazda and Volvo Needs This thread Refback 11-09-2015 08:11 AM
Strange issue... Traction light, check engine light and battery light astrob0y Powertrain 2004-2009 Mazda3 10 06-23-2011 11:44 AM
Intermittent Check Engine light & AT light stephyg Powertrain 2004-2009 Mazda3 5 05-29-2011 09:14 PM
Check engine light issue deluxman Stock Issues 15 07-26-2009 04:20 AM
MOVED: Check engine light issue RB Powertrain 2004-2009 Mazda3 0 06-07-2009 06:36 AM
MOVED: First, tire pressure light, now check engine light. what's up? mz3szoomzoom 2004-2009 Electronics Discussion 0 11-22-2005 01:49 PM
