04 2.3l swap to 2.5l successful - Page 157 - Mazda3 Forums : The #1 Mazda 3 Forum
 99Likes
post #1561 of 1565 (permalink) Old 08-05-2018, 04:54 PM
Originally Posted by rickkari View Post
I'd skip the rear main if it is good. I didn't change it on my '15 10K Fusion that i swapped in my former '04MZ3. It was fine. I used Toyota oil pan, cam housing FIPG to seal the engine. I used it for 17 1/2 years at a Toyota dealership. Bulletproof. Hope the swap goes well and I'm impressed with the purchase price for everything. Sweet. Just sharing my experience.
I got a deal on the parts for sure! I'm lucky that I live in an area where we have lots of yards to choose from. I used car-part.com to find a yard near me that had the engine, IM, and TB that I wanted. As an added bonus I could see pictures of the actual car so I knew that it hadn't been in an front-end collision. When I went to the yard they were pretty excited to hear what I was doing with this swap so they cut me pretty big breaks on the Mazda IM and TB. The engine itself was only $350!
Your thread is definitely one of the ones I'm referring to. I really appreciate all the steps you documented to get one of the newer 2.5's to work!
StrangeDuck is offline
post #1562 of 1565 (permalink) Old 11-19-2018, 11:40 PM
Not sure what state you are in. I am in California. Does anyone know how this swap would affect me smog legal wise?
jayadams66 is offline
post #1563 of 1565 (permalink) Old 11-20-2018, 01:18 PM
Datsun1600's Avatar
That's a good question to ask. If you think about the swap the way most have done it, you are stripping a 2.5L engine down to the long block (only head, block, and internals). You'll be putting back on all the Mazda external parts - valve cover, oil pan, timing cover, IM, TB. It's up to you whether you use a 2.3L or 2.5 IM&TB. You'll be retaining the EGR valve, all your Cats, and pretty much anything else that makes a California car smog legal.
I don't know if an increase in fuel consumption via larger injectors or throttle body and intake manifold will cause you to fail during a smog check. The engine will look virtually identical so it will definitely pass the "eye test."
Lots of folks on this forum have done the swap. At least one (TripWire) is from California.
'11 Ford Explorer and '13 Ford Focus
'07 Mazda3 2.5L swap and '07 Mazda3 2.3L
Datsun1600 is offline
post #1564 of 1565 (permalink) Old 11-20-2018, 04:23 PM
Banned
The OBDII must be compliant regarding the monitor status.
If you are not and you fail you will be required to go to a CALIFORNIA emission inspection center. You may get your VIN code and engine matched for California compliance.
My advise as a licence in the State of California to perform emission testing is to go to a test SERVICE SHOP and ask NOT to be connected to the STATE of California and only want a pre-test. They may or may not charge for the service? It use to be free but anymore I am sure they will charge a minimum fee. This is different than the old advertised by many service shops if you don't pass you don't pay, so DO NOT get them confused. If by chance you do pass the pre-test I would highly recommend to go the full emission test and get your certification right then.
DO NOT supply information about your mods. Let the tech do his job.
Trust me if there is a fault using your engine and you don't pass there will be nothing reasonable you will be able to get to pass it for registering in the state of California.
If you call the DMV or California Air Resource board or BAR they will all give you exact requirements or where to read what the requirements, restrictions or limitation to what is exceptable for changing from the original OEM parts on a California vehicle to pass emissions requirements. I strongly suggest if you first do not take my first recommendation consider the second. DO NOT take your car to any station that is a CA Emission ONLY test center without knowing all the information up front. Once your car is connected to the State Of California for emission testing at that point the engine used if it were a questionable concern will be marked in the states information about your car. At that point any station you go to when they connect your car that information will come up. You don't want that to happen unless you know absolutely that your modding is not an emission concern or violation.
Be careful ANY MEMBERS advise UNLESS THEY KNOW THE CURRENT EMISSION VEHICLE STANDARDS AND REQUIREMENTS FOR EMISSION TESTING IN CALIFORNIA
M3RacerX is offline
post #1565 of 1565 (permalink) Old 11-20-2018, 04:37 PM
Banned
The phrase "passing the eye test" with respect to the exact regulations...let me tell you!
An example.... during the "EYE" exam if the tech see's a universal bulk cut hose for use for a broken or leaking OEM PCV hose and even if it has emission quality or worded for emission hose requirement but not recognized as an OEM hose in some "eye" "test" will fail the emission test. Even something as mundane and generic like electrical tape none OEM used on something under the hood can fail the test. Really this state has gotten very stick. But then we are lucky we don't technically have mandatory vehicle safety inspections like some other states of countries. At worst if the engine looks like it is not original can lead the "EYE" examination to look more carefully at everything which may include the engine number used or currently in that vehicle being emission tested.
IT IS THE TECHNICIAN ASS and he and the shop could be fined for missing anything not in emission requirements.
Really the old days of slipping a Tech a "c" note to pass are all but gone.
The state sends inspectors for compliance out on the road and they can drive by the shop doing a emission test and look on the internet the car that should be connected. If they feel anything is needing further investigation they can by law enter the shop, check to verify any aspect of the emission test being done.
M3RacerX is offline
LinkBack to this Thread: http://www.mazda3forums.com/61-powertrain-2004-2009-mazda3/647562-04-2-3l-swap-2-5l-successful.html
04 2.3l swap to 2.5l successful - Page 151 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-11-2018 11:59 PM
04 2.3l swap to 2.5l successful - Page 136 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-24-2017 10:32 AM
Brother in law needs 2007 Mazda 3 non turbo motor Hendersonville Nc | Grassroots Motorsports | forum | This thread Refback 08-13-2017 10:29 PM
04 2.3l swap to 2.5l successful - Page 108 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-20-2017 06:09 PM
04 2.3l swap to 2.5l successful - Page 124 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-27-2017 10:37 PM
04 2.3l swap to 2.5l successful - Page 124 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-27-2017 10:18 AM
04 2.3l swap to 2.5l successful - Page 123 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-24-2017 02:12 AM
04 2.3l swap to 2.5l successful - Page 92 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-09-2017 06:58 AM
04 2.3l swap to 2.5l successful - Page 6 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-09-2017 06:57 AM
2.3 to 2.5 engine swap - intake adapter plate - FordFusionClub.com : The #1 Ford Fusion Forum This thread Refback 05-26-2017 05:04 PM
04 2.3l swap to 2.5l successful - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-22-2017 07:32 PM
04 2.3l swap to 2.5l successful - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-22-2017 07:32 PM
2.5 Ford Fusion engine swap This thread Refback 05-12-2017 09:51 PM
04 2.3l swap to 2.5l successful - Page 22 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-09-2017 10:58 AM
04 2.3l swap to 2.5l successful - Page 122 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-11-2017 06:29 AM
04 2.3l swap to 2.5l successful - Page 122 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-06-2017 04:22 PM
www.fmvperformance.com/forumdisplay.php?f=61 on FMVperformance.com : The site for all your Ford Mazda and Volvo needs | BoardReader This thread Refback 09-08-2016 11:08 PM
04 2.3l swap to 2.5l successful - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-16-2016 10:41 PM
04 2.3l swap to 2.5l successful - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-16-2016 10:41 PM
04 2.3l swap to 2.5l successful - Page 110 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 09:38 PM
04 2.3l swap to 2.5l successful - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 09:38 PM
04 2.3l swap to 2.5l successful - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 09:38 PM
04 2.3l swap to 2.5l successful - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 04:42 PM
04 2.3l swap to 2.5l successful - Page 110 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 04:42 PM
04 2.3l swap to 2.5l successful - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 04:42 PM
04 2.3l swap to 2.5l successful - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 04:34 PM
04 2.3l swap to 2.5l successful - Page 110 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 04:34 PM
Help with Engine swap - DFW Mazdas This thread Refback 06-06-2016 11:58 AM
04 2.3l swap to 2.5l successful - Page 100 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-25-2016 04:51 PM
04 2.3l swap to 2.5l successful - Page 91 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-01-2016 01:52 AM
04 2.3l swap to 2.5l successful - Page 88 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-03-2016 05:41 AM
FMVPerformance.com Network: The sites for all your Ford Mazda and Volvo Needs This thread Refback 08-26-2015 12:32 PM
FMVperformance.com : The site for all your Ford Mazda and Volvo needs This thread Refback 07-27-2015 06:03 PM
Everything you need for a successful repair job carid CARiD.com 0 10-03-2014 05:38 AM
Successful mods? jiggydancer Modifications 1 04-20-2004 11:19 AM
