06 3 with only 17,000km and it sounds / feels fine up until about 60 clicks and once up to 70kmh seems to bounce or flutter. The WHOLE car feels like it is bouncing. It doesn't chug, but bounces / flutters. We just had a huge snowstorm here and ended up having to really jerk the car around this weekend in order to navigate home from work. Got stuck a few times. Maybe this has something to do with it? Car is still under warranty, so probably going there this week anyways.
Same car last week started when I lightly hold the accelerator down and maintain constant speed, engine becomes quite loud and sounds like grinding (?). but it sounds like an 1986 Oldsmobile or something. Doesn't matter what speed I'm travelling.
finally got the car into my garage to warm up here for a few hours one night. Everything thawed out and took er out for a hard spin and vibrations and sounds have stopped. So im guessing everything in the car was just damn cold.
Remember california boys, there was 2 feet of snow on the road and temperatures were -30C haha.
Hell, if it ends up being a busted strut, just gives me another excuse to lower her in the spring!!1
I have the same problem. The dealer told me my front passenger shock was leaking oil and they replaced it on warranty a few months back. However, this only provided temporary relief and my car started bouncing again a few weeks later. I thought that my tires might be seriously unbalanced at the time. 2 days ago my clutch broke while I was driving down a mountain road and I had to tow my car 65 miles to the nearest dealer. When a Mazda mechanic inspected it, he told me that the engine mount was broken too.
I think the broken engine mount may have contributed to the strut leaking oil and my clutch getting destroyed. Unfortunately, I'm 5k over the 50k warranty limit.
If I were you I'd make sure they at least check the mounts and struts. Hope things work out for you at the dealer.
Also, you depending on the year of your Mazda you may be able to ask the dealer to give your a revised engine mount.
Subject:
ENGINE VIBRATION / KNOCKING NOISE / NO.3 ENGINE MOUNT RUBBER BROKEN
Bulletin No: 01-035/07
Last Issued: 08/08/2007
Service Bulletin Mazda North American Operations
Irvine, CA 92618-2922
MULTI-MODEL - ENGINE VIBRATION / KNOCKING NOISE / NO.3 ENGINE MOUNT RUBBER BROKEN
BULLETIN NOTE
This bulletin supersedes the previous bulletin 01-021/05 issued on 07/13/05. The DESCRIPTION, APPLICABLE
MODEL(S)/VINS, and PART(S) INFORMATION have been revised.
APPLICABLE MODEL(S)/VINS
2004 – 2006 Mazda3 with VINs lower than JM1 BK**** ** 533507 (Produced before May 8, 2006)
2006 Mazda5 with VINs lower than JM1 CR**** ** 127354 (Produced before May 8, 2006)
DESCRIPTION
Some vehicles may exhibit a knocking noise from the engine compartment when starting/shutting off the engine
or may experience excessive engine vibration at idle. A likely cause of this is a broken No. 3 engine mount. This
symptom could be observed under any condition such as accelerating or idling with the engine hot or cold.
The No. 3 engine mount rubber has been modified to address this concern.
Customers having this concern should have their vehicle repaired using the following repair procedure.
2004-2007 MAZDA3, 2006-2007 MAZDA5 - BODY VIBRATION AT CRUISE SPEED
BULLETIN NOTE
This bulletin supersedes the previous bulletin 03-001/06 issued on 7/21/2006. The APPLICABLE MODEL(S)/
VINS section has been revised.
APPLICABLE MODEL(S) / VINS
2004-2007 Mazda3
2006-2007 Mazda5
DESCRIPTION
Some vehicles may experience a body vibration when driving approximately 55mph. This symptom is due to the
characteristics of the No. 3 & No. 4 engine mounts.
Modified No. 3 & No. 4 engine mounts have been established for service only. Customers having this concern
BULLETIN NOTE
2004-2007 Mazda3
2006-2007 Mazda5
DESCRIPTION
This has turned out to be really helpful. I have noticed this happening to me, when i get around 55mph. I guess I should take it in to get it looked at. Thanks.
[quote author=beekae link=topic=162381.msg3456122#msg3456122 date=1260769382]
WOW. how much was that bill?
Related Threads
Mazda3 Forums
4.3M posts
249.5K members
Since 2000
