turbo fmu questions - Mazda3 Forums : The #1 Mazda 3 Forum
 2Likes
  • 1 Post By 1Cleanm3
  • 1 Post By okellyr
post #1 of 7 (permalink) Old 03-20-2016, 12:33 AM Thread Starter
1Cleanm3's Avatar
turbo fmu questions
Hi, it has been a wile since I posted but I now in the process of piecing together a turbo kit. My question is: If I am running a T28 turbo at 7to8 psi, what should I upgrade as far as fuel pump or adding FMU or regulator? I figured to upgrade the fuel pump to a 255 Walbro but what else?
I have searched already and can't seem to find the forum for this particular subject. What do you al recommend or know the link to the right area for this? thanks!
Adam3324 likes this.
2006 Mazda 3i - ready to be boosted!
1Cleanm3 is offline
post #2 of 7 (permalink) Old 03-24-2016, 08:15 AM
I am looking into piecing together a turbo kit as well. I came across this forum. Hope this helps.
hogi13 is offline
post #3 of 7 (permalink) Old 03-24-2016, 09:46 AM
Send a message via AIM to xxxmonoxidechild
Your car has a returnless fuel system. A FMU or regulator will not work on your application. Both are for Return Style fuel systems.
Im boosting my 2.3 currently. And im actually converting the stock returnless fuel system over to a common Return style. That way i can have alot more control over the fueling, and not let the ECU handle all that. But to do so, you need to have your fuel rail modified, run a return line back to the fuel tank, and also re-wire the fuel pump itself so it sees a constant 12v when on.
xxxmonoxidechild is offline
post #4 of 7 (permalink) Old 03-25-2016, 10:09 AM
okellyr's Avatar
Yep... all that and a bag of chips...
The reality is that the stock pump will just about satisfy the fuel demands for 7 - 8 psi .... its right on the edge though...
Boosted baby....
BOOSTED
okellyr is offline
post #5 of 7 (permalink) Old 03-27-2016, 12:03 AM Thread Starter
1Cleanm3's Avatar
Thanks for the replies! So, I will just try to see if my stock pump will run it. If you had to upgrade, would you go with the Walbro?
1Cleanm3 is offline
post #6 of 7 (permalink) Old 04-01-2016, 10:21 AM
epic3's Avatar
Send a message via AIM to epic3
Stock pump can handle up to 12 no issues... That's when you start skirting on running out of pressure. A lot depends on the turbo, injector size, etc... You'll be fine until you're not.
epic3 is offline
post #7 of 7 (permalink) Old 04-01-2016, 03:36 PM
I went with a Walbro 250HP for my setup. But thats because with the return setup ill be running, any excess fuel will just find its way back to the tank anyways. So its just better safe then sorry. Im not sure what my Greddy turbo is going to need yet, and figured id just knock out that now instead of having to potentially get into it again down the road.
LinkBack to this Thread: http://www.mazda3forums.com/343-forced-induction-discussion/705786-turbo-fmu-questions.html
Forced Induction Discussion [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 03-24-2016 10:26 AM
Turbo Questions joel1618 Powertrain 2004-2009 Mazda3 2 06-10-2011 12:41 AM
Turbo Questions? strike_out73 Forced Induction Discussion 29 11-10-2009 10:07 PM
F2 Turbo questions shinazda3 Forced Induction Discussion 77 03-01-2009 06:19 PM
Hiboost turbo questions!! weezerfan84 Forced Induction Discussion 60 10-29-2007 05:38 PM
Turbo questions 66Racer Forced Induction Discussion 2 02-01-2006 01:36 AM
