MazdaEdit - Setup - Page 13 - Mazda3 Forums : The #1 Mazda 3 Forum
post #121 of 124 (permalink) Old 10-15-2014, 12:03 PM Thread Starter
okellyr's Avatar
Map tables = do something but don't scale the map sensor ! Lol
Boosted baby....
BOOSTED
okellyr is offline
post #122 of 124 (permalink) Old 02-08-2015, 01:31 PM
slomz3's Avatar
Any updates on the software and tables?
slomz3 is offline
post #123 of 124 (permalink) Old 02-08-2015, 10:30 PM Thread Starter
okellyr's Avatar
There were a few patches rolled out and it does seem to be a little more stable ... And have come to the conclusion that the personal version needs to have the hex and XML functionality that the pro version has for it to become truly valuable ...
As far as tables go I suspect there is great variability of what u see depending on ecu type ( of which there are a few ) ... me I don't have access to all the map tables , the ltft zone tables and a few others which is incredibly frustrating .... And can't be worked around without someone with experience and who has the pro version ... = it's limited depending on what u are doing
In short the app as stands will be fine for na tuning and hobby messing about but for an fi conversion it will get u close but the limitations will be problematic
A thing I did learn recently , or should I say confirmed a suspicion , a map sensor upgrade is a must for fi ... The stock one max's out about 115 kpa and I had noticed that the load calcs ( which are based on maf ) capped out somewhere between 79 and 84% when the map topped out and I suspected there was a linkage of some type that caused the load calc to cap out... Now that I have a 3bar map running the load calcs run up to 92 + % no issue = there is some sort of linkage or control algorithm at play
Boosted baby....
BOOSTED
okellyr is offline
post #124 of 124 (permalink) Old 12-25-2019, 09:24 AM
Guys i'm new to MazdaEdit and maybe someone can help me. There is anything i did wrong before the Flash Process, but i don't know what.
Everything (Programm, OP Connector, VIN) is registered, but i receive the following Error when i try to flash a Stock MAP. See Screenshot
Is it maybe because that the Ignition is already on before i choose the Flash Button? Or must i something select in the MAP before sending to Flash Utility?
DEATHROW is offline
LinkBack to this Thread: http://www.mazda3forums.com/343-forced-induction-discussion/603202-mazdaedit-setup.html
Forced Induction Discussion [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 09:28 AM
LOST Discussion VRMS6 Lounge 1054 05-26-2010 10:17 PM
Rubber Discussion masterallen Wheels / Tires 1 04-02-2009 01:14 AM
Why is there no discussion on swaps? sirs1ayer Modifications 43 02-13-2007 09:14 PM
Yet another tranny discussion the415 Forced Induction Discussion 31 09-07-2006 08:05 PM
