MazdaEdit - Setup - Page 11 - Mazda3 Forums : The #1 Mazda 3 Forum
post #101 of 124 (permalink) Old 05-20-2014, 04:43 PM Thread Starter
okellyr's Avatar
having trouble changing the AFR target... asked joe for some help and he is looking at it now
Boosted baby....
BOOSTED
okellyr is offline
post #102 of 124 (permalink) Old 05-21-2014, 07:34 AM Thread Starter
okellyr's Avatar
I am thinking the closed loop afr thanked are for cruising ....
Boosted baby....
BOOSTED
okellyr is offline
post #103 of 124 (permalink) Old 05-22-2014, 10:51 AM Thread Starter
okellyr's Avatar
Looks like
14.7 afr is baked into the rom
Closed loop tables look like they relate to cruse afr
Open loop works fine but may not be actual afr targets or if they are they are subject to adjustment by the ecu
Boosted baby....
BOOSTED
okellyr is offline
post #104 of 124 (permalink) Old 05-23-2014, 09:01 AM Thread Starter
okellyr's Avatar
LTFT range tables not defined currently ... am waiting on MEP people to come back... hell if hey gave me the pro version id go hunting myself... anyhow
Confirmed yesterday
>> ignition table adjustment works
>> VVT and EGR adjustment appears to work
>> Idle control adjustment works
>> Skewing Load calcs using MAF curve works and is proportionate to the Injector scaler ( reduce or increase one by x and apply the same to the other
Boosted baby....
BOOSTED
okellyr is offline
post #105 of 124 (permalink) Old 05-23-2014, 08:20 PM Thread Starter
okellyr's Avatar
Load tables may not be absolute load but some other load ? Not sure
Boosted baby....
BOOSTED
okellyr is offline
post #106 of 124 (permalink) Old 05-28-2014, 02:30 PM Thread Starter
okellyr's Avatar
Quick update on a few things
>> OL/CL transition testing underway - Adjusted the brake point tables and logging
>> MAF Scaling / Skewing = Works ... One can adjust the absolute load calcs by skewing...
>> Tables that are not there and should be = I should have the LTFT brake point tables but I don't and epifanSoftware indicate that they are there in the hex but they have not found them yet... Moreover they will not commit to finding them ... = either upgrade to the professional version ($700) and find the tables myself or contact DT and ask for them to do it.... the upshot is that there are no guarantees that the hex file the vendor gives you will be complete and or what u need and that the return to you is probably highly dependent on the ECU you have.... and if you think about it that's a less than ideal situation... if u buy a product and its found to be missing something that something should be added
Boosted baby....
BOOSTED
okellyr is offline
post #107 of 124 (permalink) Old 06-01-2014, 01:01 AM Thread Starter
okellyr's Avatar
MazdaEdit discussion
Failing to force her into ol .... Was using the accel thresholds primarily so I'm going to give here a whack with the load thresholds set low and see what happens
Boosted baby....
BOOSTED
okellyr is offline
post #108 of 124 (permalink) Old 06-03-2014, 09:29 PM Thread Starter
okellyr's Avatar
May be an other fail for Mazda edit = open loop delay table is missing and I already know what they will say ... Ohhh well maybe we will get to it one day maybe not ... Unfortunately it's an important table
Boosted baby....
BOOSTED
okellyr is offline
post #109 of 124 (permalink) Old 06-03-2014, 11:49 PM Thread Starter
okellyr's Avatar
So far Mep has done basically an ok job but the response of the vendor to requests for table definitions is less than stellar and somewhat disconcerting ...
Boosted baby....
BOOSTED
okellyr is offline
post #110 of 124 (permalink) Old 06-28-2014, 05:32 PM
pbjunkie's Avatar
I appear to have driver issues
Been trying to connect to ecu but when entering logging to verify obd2 connection i get (can't open port tactrix openport 2.0 j2534 vehicle interface j2534 dll not found or supported op20pt32.dll) ).have tried reinstalling drivers with dll from tactrix even as admin and dosnt seem to be working. I am wondering if i should pull those drivers and try ecuflash with drivers, any better chance of that working with mazdaedit. Would really love to get dump file to dt. Any help wold be cool i have already had them on teamveiw a few times and got vin and device key done. or is this a port issue ill have to have them dial in.
06Mz3i-RX8 rims-kuhmo-koni str-t-eibach pro-gorrila lug-anzo tails-spyder yellow fogs-ebc brakes
pbjunkie is offline
LinkBack to this Thread: http://www.mazda3forums.com/343-forced-induction-discussion/603202-mazdaedit-setup.html
Forced Induction Discussion [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 09:28 AM
LOST Discussion VRMS6 Lounge 1054 05-26-2010 10:17 PM
Rubber Discussion masterallen Wheels / Tires 1 04-02-2009 01:14 AM
Why is there no discussion on swaps? sirs1ayer Modifications 43 02-13-2007 09:14 PM
Yet another tranny discussion the415 Forced Induction Discussion 31 09-07-2006 08:05 PM
