How to: Change the Color of your Radio LCD (Pictures) - Page 15 - Mazda3 Forums : The #1 Mazda 3 Forum
post #141 of 161 (permalink) Old 06-20-2010, 02:03 PM Thread Starter
Send a message via AIM to Rdk87 Send a message via MSN to Rdk87
Re: How to: Change the Color of your Radio LCD (Pictures)
julieA,
As for the radio LCD, if you get it from the same make model and year as your 2007 it will work with out needing to be reprogrammed, I can't say for sure with newer/older years. Before I started this project I found an entire used radio unit pulled from a burned out vehicle for 34 dollars on ebay, it came with the cdplayer as well as the screen, and I tested the screen on my current radio install. so they are swappable. It is always a good idea to make sure you have a backup before doing something like this. Although 3 years later, I'm still stuck with my extra radio/lcd screen I'm sure one day they will be needed.
-R
How to Change the color of your Gauge/Radio LCD
Rdk87 is offline
post #142 of 161 (permalink) Old 07-19-2010, 09:26 AM
yeah im still trying to locate a 2007 bose system radio w/ lcd and no such luck.
julieA is offline
post #143 of 161 (permalink) Old 07-19-2010, 08:56 PM Thread Starter
Start here
http://cgi.ebay.com/ebaymotors/2006-...fAudioQ5fVideo
Although I'm not sure if the Bose audio system is different beyond just the speakers, I'm guessing the center console is the same in Bose and non Bose setups, so you would just need to find an entire set to work with your 07. Some of them are a little pricey because they have the six disk cd changer in them but there were a few for the 07 on ebay for 100 or less.
Either way doing ebay searches for OEM radio's is a good place to start looking.
-r
EDIT: Fixed Link.
Rdk87 is offline
post #144 of 161 (permalink) Old 07-19-2010, 10:56 PM
i read somewhere that the bose HU is actually different...in terms of setup..and that I would need a bose one. But I was planning on trying the LCD display too, but wasnt sure if taht had to be the same. But if not then may try taht first. and yea, mine is a 6disc, so thats sorta what i have been looking for, and forgot to add I was looking for cheap
Also Rdk, I was looking at superbrightleds for the 3mm LEDS suggested, but was wondering if the min and typical energy rating has to be that? or if anybody else on here has tried a different color also try a different energy rating? mainly cause mine are not close to that at all.
julieA is offline
post #145 of 161 (permalink) Old 07-19-2010, 11:48 PM
immayo's Avatar
I wish i knew how to use a soldering gun... i want to do mine like this in purple eventually
immayo is offline
post #146 of 161 (permalink) Old 07-19-2010, 11:51 PM
im going for a nice green color
julieA is offline
post #147 of 161 (permalink) Old 07-20-2010, 12:47 AM Thread Starter
I can't say exactly because I don't know the exact cut for the min and typical energy rating in terms of where the led's will just straight burn out, but I do know that I bought green and blue with the typ and min that I posted and they both worked, but before that I ordered some super bright ones that had a much higher typ and min and they wouldn't light at all in testing, let me see if I can find those... * searches through year old records * I couldn't find the typ and min of the super bright LED's I found the package but no info on there
Just aim for a close typ and min and you should be okay, I did buy both blue and green when i was testing so I know there are green LEDS out there that will work for you for sure if you do end up changing out your radio LCD screen.
[quote author=julieA link=topic=69809.msg3733180#msg3733180 date=1279594591]
Rdk87 is offline
post #148 of 161 (permalink) Old 07-20-2010, 01:30 AM
has anybody actually blown a bulb in those?
dark96 is offline
post #149 of 161 (permalink) Old 07-20-2010, 03:50 AM Thread Starter
In what? The LCD screen? They don't use bulbs so there shouldn't be any blowing out, they are LEDs, and they have a very long life so I'm sure there have been a few burn outs here and there but since there are three LEDs on each side all three would have to burn out before anyone really would take notice.
[quote author=dark96 link=topic=69809.msg3733330#msg3733330 date=1279603855]
Rdk87 is offline
post #150 of 161 (permalink) Old 07-20-2010, 09:02 AM
ah..gotcha. thanks
dark96 is offline
LinkBack to this Thread: http://www.mazda3forums.com/149-interior-mods-technical-information-faqs-how-tos/266119-how-change-color-your-radio-lcd-pictures.html
Change LCD color of stock head unit - Unofficial Honda FIT Forums This thread Refback 05-22-2016 01:33 AM
Interior Mods Technical Information, FAQ's, How-To's [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 07:37 AM
