How to: Change the Color of your Radio LCD (Pictures) - Page 11 - Mazda3 Forums : The #1 Mazda 3 Forum
post #101 of 161 (permalink) Old 05-26-2008, 04:46 PM
Re: How to: Change the Color of your Radio LCD (Pictures)
i had the polarity lined up correct but i already put everything back together so i'll just wait until i go home and have more time on my hands to mess around with this stuff. i hope i didn't fuck up that contact point
Injen | Progress | Kumho | Vibrant | Apexcone | EBC | Shiftstyle | RKM | Audiolink | Kicker | Hifonics
Click for my pic thread!!!
bdubs16 is offline
post #102 of 161 (permalink) Old 05-26-2008, 05:41 PM Thread Starter
Send a message via AIM to Rdk87 Send a message via MSN to Rdk87
yeah I had a problem like that -
not on my cluster but on my radio --
My pa had given me one of those COld- Hot electric soldering guns -- that apparantly heat up to like a million degrees super fast ... well lets just say it says on the instructions " don't use on electronics " which of course I read after applying it to an LED. it burned not only the contact point off ( melted it into nothingness ) but it burned a tiny hole in the actually circuit board itself .. yeah .. so I messed around for quite awhile with a real soldering gun and made a kind of solder line from the contact of the led all the way to the far part of the soldering board where it attached .. that seemed to do the trick.
If you can't reach the point to solder you might try dremeling away the plastic thats in your way ? as long as that wont mess up putting the whole thing back together? Either that or get a soldering gun with multiple tips -- some have pretty small tips like a cheap one that I have.
How to Change the color of your Gauge/Radio LCD
Rdk87 is offline
post #103 of 161 (permalink) Old 05-26-2008, 06:17 PM
yea i just couldn't find anyone that carried weller tips and i'm gunna mess around with it some more when i go home and see if my friend can help me out. its just my gas and temp needles so its not that big of a deal.
bdubs16 is offline
post #104 of 161 (permalink) Old 05-26-2008, 08:03 PM
Send a message via AIM to Commie
Damn, sounds like you might have melted a piece of your circuit. If unsoldering/resoldering won't help then you may need to try what rdk said. I guess just scratch away at the circuit until you find some unmelted or undamaged connections and work from there. Good luck!
Commie is offline
post #105 of 161 (permalink) Old 05-26-2008, 08:10 PM
yay!!! i can't f-ing wait
bdubs16 is offline
post #106 of 161 (permalink) Old 05-26-2008, 10:55 PM Thread Starter
yeah thats how I felt when I put a hole in my radio BOARD X_X but int he end it worked out! and it will work out for you too!
Rdk87 is offline
post #107 of 161 (permalink) Old 05-26-2008, 11:42 PM
thanks for the positive comments guys and i'll keep you updated with some new pics (hopefully better quality ones) when it's all said and done.
bdubs16 is offline
post #108 of 161 (permalink) Old 05-28-2008, 07:44 PM
Hey Rdk87 so I'm looking at the LCD on the cluster (with the odometer/trip meter). I can't seem to find a good way to get to the LEDs without unsoldering the ~20 connections behind the LCD. Did you find a better workaround?
Commie is offline
post #109 of 161 (permalink) Old 05-28-2008, 09:12 PM
[quote author=Commie link=topic=69809.msg2348068#msg2348068 date=1212018248]
Not trying to step on Rdk87's toes here, just putting in my
I found that the was the easiest/cleanest way to do it for me. I saw one howto that suggested dremeling (if that's even a word) away at the plastic to get underneath it to the LEDs, but that just seemed too messy and risky with it still on the board. Once I desoldered and removed the LCD I found that that method wouldn't have worked for me anyway since aparently my cluster had 4 LEDs under the LCD and the one in the howto only had 2.
dacuda is offline
post #110 of 161 (permalink) Old 05-28-2008, 09:30 PM
[quote author=dacuda link=topic=69809.msg2348292#msg2348292 date=1212023577]
Oh ok awesome, so you ended up desoldering all the ~20 points? I'll do it if I have to, I just won't be happy :P
Commie is offline
LinkBack to this Thread: http://www.mazda3forums.com/149-interior-mods-technical-information-faqs-how-tos/266119-how-change-color-your-radio-lcd-pictures.html
Change LCD color of stock head unit - Unofficial Honda FIT Forums This thread Refback 05-22-2016 01:33 AM
Interior Mods Technical Information, FAQ's, How-To's [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 07:37 AM
