quick question/advice! - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 7 (permalink) Old 04-15-2010, 11:06 AM Thread Starter
so i have a 04 mazda 3s with a hps cold air intake and i am installing a borla catback this saturday, after thats done i'm trying to figure out what i should do after that. any suggestions? much appreciated.
mazda3owner04 is offline
post #2 of 7 (permalink) Old 04-15-2010, 11:11 AM
Send a message via AIM to a-sher
Re: quick question/advice!
throttle body ground, aftermarket motor mounts, sway bars, springs, shocks, wheels, tires. It all depends on what you want to get out of your car.
Id go with a rear sway bar and cheap or freebie mods.
TB ground, VCTS delete, indy fogs, maybe DDM hids, balance shaft delete.
a-sher is offline
post #3 of 7 (permalink) Old 04-15-2010, 11:12 AM
hey click the link in my sig OP!
Rally White 2005 Mazda3 S - Lentech street terminator, Trubendz, AWR, VTCS, Apexcone 5000k lows, Alpine HD137BT stereo, Alpine FRP and MRP 450 amps, 5 farad cap, 12" Type-r @ 2Ω, Infinity Kappas 5x7.
Super Black 2004 Murano SL - Luxury Package bone stock
3driverPa is offline
post #4 of 7 (permalink) Old 04-15-2010, 12:33 PM
I suggest installing a straight/race pipe/cat-delete. I installed one after I installed my borla and the difference was definitely noticeable. I'd have someone weld in some flanges though so its swappable with your stock cat for inspection purposes. After that I'd say tints, HID's, or springs.
bboytails is offline
post #5 of 7 (permalink) Old 04-15-2010, 05:45 PM
the borla exhaust is great but it sounds fantastic if you add some vibrant headers. depending on how you are with emissions then a straight pipe is also another great route along with this setup. the freebe mods are nice also do the VTCS removal, throttle body ground, and if you dont get harsh winters do the throttle body bypass with teh coolant.
pinkcheese is offline
post #6 of 7 (permalink) Old 04-15-2010, 10:06 PM Thread Starter
what does grounding the throttle body do? and i was thinking of getting that hypertech chip kinda of thing were it plugs into the obd 2 port? its a bit expensive for little hp tho..so idk.
Thanks for all the suggestions! keep em cominn
post #7 of 7 (permalink) Old 04-15-2010, 10:10 PM
[quote author=mazda3owner04 link=topic=170825.msg3619249#msg3619249 date=1271383583]
increase response in the pedal. ive heard there are a few hp gained from it. if anything its just nice to have.
