Starting issues when hot, tough steering - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 10 (permalink) Old 01-13-2016, 05:34 PM Thread Starter
Hey guys
So I took the car back to the shop, turns out a pipe was broken inside the pump and it was replaced, car was fine afterwards.
Thing is, the car starts fine, and runs OK for 3-4 miles then it gets tough, the steering gets harder and I feel that the gas pedal is heavier, when I stop it and try to start it again it won't start! It cranks but won't start.
It happened today and after several start attempts the car started but after 3 miles it got stiff again. I'm clueless where to begin!
I noticed another thing, I don't know if it's relevant, I even posted about it and no one replied, that after I turn it off it leaks coolant fluid from a crack on the side of the tank, I always try to top it up, and the car's heat gauge is never over half, could it be over heating?
I might take it for an inspection tomorrow, but I need pointers, please help!
P.S: I have a check engine code, but I don't know what it says as my OBDII won't work.
Muaad is offline
post #2 of 10 (permalink) Old 01-14-2016, 01:41 AM
okellyr's Avatar
Ok the code is probably super important... I don't think you are over heating if there is still coolant in the reservoir and I DONT THINK you should be driving the car... IDK what wrong but the description you give makes me think that its something small that is important and potentially dangerous ...
Is the brake fluid reservoir full? ( the power steering uses the same reservoir )
Boosted baby....
BOOSTED
okellyr is offline
post #3 of 10 (permalink) Old 01-14-2016, 02:22 AM Thread Starter
@okellyr thank you for the reply.
I checked it a few days ago and it was full. I'll check it again.
And I'm not driving the car, I just tested it to see if it was fully repaired, looks like it wasn't.
I'll check again for that reservoir!
Muaad is offline
post #4 of 10 (permalink) Old 01-14-2016, 10:22 AM
okellyr's Avatar
just get it to a garage and i think they will diagnose the thing fairly quick and you will be good ... mind u my stomach sinks every time i have to ( though super rare these days )!
Boosted baby....
BOOSTED
okellyr is offline
post #5 of 10 (permalink) Old 01-14-2016, 02:55 PM Thread Starter
Don't we all?
I became a regular at the shop, and my stomach sinks regularly.
I checked the code, it's 0433
And added oil to the reservoir. It was missing below minimum!!
The steering wheel is a bit smoother, for now..
Muaad is offline
post #6 of 10 (permalink) Old 01-14-2016, 03:48 PM
okellyr's Avatar
433 = Heated Catalyst Efficiency Below Threshold (Bank 2)
Boosted baby....
BOOSTED
okellyr is offline
post #7 of 10 (permalink) Old 01-15-2016, 02:55 AM Thread Starter
Thanks for sharing the code meaning, but could you be more specific? I'm not very familiar with these terms!
Muaad is offline
post #8 of 10 (permalink) Old 01-15-2016, 10:55 PM
Classic catalytic converter symptom.
OBDII Code P0433 - Heated Catalyst Efficiency Below Threshold Bank 2 | HelpForCars.net
'07 Mazda 3s - Daily Driver
'10 VW CC 2.0 - Pushing 386 WTQ and 421WHP
Willy_Nilly is offline
post #9 of 10 (permalink) Old 01-16-2016, 01:33 AM
Are you sure that is the correct code as our cars don't have a "bank 2".
post #10 of 10 (permalink) Old 01-16-2016, 10:19 AM Thread Starter
Only one code 0433, the shop says the Solenoid isn't connected properly, I'm yet to check on that (they don't work today).
Muaad is offline
LinkBack to this Thread: http://www.mazda3forums.com/122-stock-issues/700033-starting-issues-when-hot-tough-steering.html
Stock Issues [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-05-2017 02:09 AM
FMVPerformance.com Network: The sites for all your Ford Mazda and Volvo Needs This thread Refback 01-16-2016 07:53 AM
Starting issues. Mazddie Powertrain 2004-2009 Mazda3 3 06-15-2015 03:42 PM
Starting issues. Mazddie Powertrain 2004-2009 Mazda3 12 08-31-2013 12:50 PM
Starting Issues bclown90 Stock Issues 9 11-29-2011 09:05 PM
not starting issues beachgirl Stock Issues 7 03-14-2009 09:53 PM
Starting issues and performance issues Twinzer Stock Issues 12 10-15-2005 03:40 PM
