Motor mount replacement: OEM or after-market? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 97 (permalink) Old 01-10-2014, 09:03 PM Thread Starter
chaos's Avatar
The dealership today told me one of my motor mounts is busted. I believe he said it's the passenger side (he said it's just the one that's hydraulic). He quoted me at $200 (labor included) to replace it. Should I go ahead and do that, or look at an aftermarket option? Do they replace the old/bad motor mounts with the same exact type that broke? I don't want to have to do this again after another 75K and I know this is a notorious problem with my generation 3. Have they improved the OEM replacement mounts for these cars or should I go aftermarket (and if the latter, any solid recommendation)?
FYI: Mazda3i i Touring sedan 2.0 L ATX, stock engine, 75K miles.
Edit: Also, should I get them all replaced (how many are there)?
I asked the guy at the dealership and he said only that one motor mount is the hydraulic type and the others are different, so he suggested I only replace the one since the others should hold up fine. Does that sound right?
'09 2.0 ATX | Lip Spoiler | JDM Visors | Enkei RPF1 | PureContact | Hawk HPS | Roca MM | Simota SRI
chaos is offline
post #2 of 97 (permalink) Old 01-10-2014, 09:13 PM
fruitloops's Avatar
Passenger is always the one that goes lol. Buy a JBR passenger side motor mount and install it yourself. Everyone loves this motor mount, and i will personally be buying one myself soon. Its 185 on their website, so it will cost you about the same amount, but you will be getting a way better product.
Bought, not Built
fruitloops is offline
post #3 of 97 (permalink) Old 01-10-2014, 10:29 PM Thread Starter
chaos's Avatar
Is there a specific product/model # for the one I'd need? I'm assuming I probably shouldn't try to do it myself--I have only basic tools, no means to jack up my car (no garage, live in apts), and very basic mechanical skills at best. So unless it's an very easy can't-mess-up DIY, I'll still need to outsource the labor. But if that mount is a no-brainer better investment than the OEM replacement the dealership would install, I might still consider buying it and having them install it for me.
chaos is offline
post #4 of 97 (permalink) Old 01-10-2014, 10:59 PM
Moderator
Cab0oze's Avatar
Bit of a generalization there... quite a few people find aftermarket PMMs too harsh IIRC. But if you buy OEM and you're planning on keeping the car for ages, it may tear again... who knows. Check out the prices though, and buy the part online, not from the dealership. Should probably save you some $$s.
Can't comment on the installation, but if you don't even have a jack I'm pretty sure you can rule the DIY out. A jack is mandatory for most MM installs because if your engine shifts you're sure as hell not going to be able to lift it by hand lol
Cab0oze is offline
post #5 of 97 (permalink) Old 01-11-2014, 08:55 AM
philrab's Avatar
Could look into ROCA USA like I got. Very close to OEM, but solid rubber. Honestly after break in it feels pretty much like stock.
philrab is offline
post #6 of 97 (permalink) Old 01-12-2014, 12:41 PM Thread Starter
chaos's Avatar
In looking for an aftermarket solution I keep coming across the DEA brand motor mounts. Anybody know if DEA is any good? I'm keeping JBR and ROCA in mind too, just looking at what else is out there to compare.
chaos is offline
post #7 of 97 (permalink) Old 01-12-2014, 12:44 PM Thread Starter
chaos's Avatar
Also, if I'm going to buy the part myself, what all do I need to make sure is included? Do I need to include any bushings, ball joints, bearings, etc.? For ex.: http://www.ebay.com/itm/ROCA-Mazda3-...-/180897264205 Is that all I'd need right there?
chaos is offline
post #8 of 97 (permalink) Old 01-12-2014, 03:56 PM
dahoov's Avatar
+1 on the JBR. But yes that's all you need. Corksport also makes urethane inserts to replace the hydraulic stuff that our cars come with, depending on what part of your mount failed
dahoov is offline
post #9 of 97 (permalink) Old 01-12-2014, 06:48 PM Thread Starter
chaos's Avatar
The JBR's I looked up are well over $100 and look like high performance, am I wrong? I don't need performance--just OEM equivalent at minimum (but hopefully more durable).
I'll probably just go with that ROCA unless there's a definite reason I shouldn't.
chaos is offline
post #10 of 97 (permalink) Old 01-12-2014, 07:04 PM
brandini's Avatar
There's OE fluid filled, there's ROCA solid rubber, and aftermarket.
ANY aftermarket mount on the passenger side will be much more than most want, so start with ROCA.
I just ordered mine from ebay, have a fluid filled now but I have a stiffer aftermarket lower rear mount.
brandini is offline
LinkBack to this Thread: http://www.mazda3forums.com/122-stock-issues/594962-motor-mount-replacement-oem-after-market.html
Stock Issues [Archive] - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 03-12-2016 06:19 AM
Stock Issues [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 12:46 AM
Front Motor mount replacement Question putzee52 Powertrain 2004-2009 Mazda3 9 01-05-2011 04:06 PM
Replacement Rear Motor Mount - CP-E VS AWR which is best? seniorgeek MazdaSpeed3 Modifications 11 07-03-2010 01:02 PM
Motor Mount Replacement R2M3 Stock Issues 10 10-16-2009 02:25 AM
FS: MS3 OEM Struts/Springs, OEM Airbox, OEM Motor Mount ndedomin For Sale | M3F 7 09-17-2008 03:00 AM
replacement motor mount fuctstar Stock Issues 1 01-31-2008 12:20 PM
