Car won't turn over (fixed, cable connection to starter janky) - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 18 (permalink) Old 10-20-2013, 01:38 AM Thread Starter
GGood's Avatar
Success! It turns out it was the cable going to the starter. Thanks okellyr! I think it's the smaller one that branches off the main bundle. I had to do everything from above tonight so I didn't get a great view of what I was doing. Funny thing is, I think my mechanic replaced a connector having to do with that about 6 months ago when my car wouldn't start after removing the VTCS butterflies...
It's just weird that something like that would happen when the car wasn't driven at all between when it was first started up today and when it stopped working. And I hadn't been poking around in there or anything either.
GGood is offline
post #12 of 18 (permalink) Old 10-20-2013, 03:54 PM
okellyr's Avatar
Yea ... Glad my pain was helpful hahaha ... It was a sob to diagnose and a serious pia to fix... Glad ur rolling again ....
Boosted baby....
BOOSTED
okellyr is offline
post #13 of 18 (permalink) Old 10-20-2013, 04:09 PM Thread Starter
GGood's Avatar
It was! hehe
I'll still have to get under my car for a more permanent fix, but I'll wait for a warmer day to do it.
DT tune | Borla CBE | VTCS | Buddyclub | Tripoint RSB | STR.Ts | RB springs | Synthetic fluids
GGood is offline
post #14 of 18 (permalink) Old 10-25-2013, 07:37 PM
okellyr's Avatar
I actually went to Mazda with this and when they saw the after market stuff they just walked away lol ... I wouldn't mind so much but they said all the clothes were wrong and I was popping fuses ... They were not and the fuses were fine !
I had to basically check everything myself ( not a bad thing ) and literally stumbled across the problem hahaha freaking took 2 hours of messing about though
Boosted baby....
BOOSTED
okellyr is offline
post #15 of 18 (permalink) Old 10-25-2013, 09:34 PM Thread Starter
GGood's Avatar
....2hrs?!? LOL
I spent literally 5 hours that day before I tried what you recommended... LOL!
Still really need to get under there, hopefully this weekend. Since I brought it to the mechanic earlier today (for something else) it's been crapping out again.
GGood is offline
post #16 of 18 (permalink) Old 11-02-2013, 10:15 PM Thread Starter
GGood's Avatar
Wow, finally got around to getting under the car today (warm day) and jeez that a PITA! The S terminal's connection is pretty loose and there's seemingly not too much I can do about it. I wire brushed the terminal and added some dialectic grease to the plug (it seemed like there was already some white-ish grease in there?) then reattached it and zip tied the cable so it wouldn't move quite as much. As far as getting the little black plastic box open... good GOD! It's like they intentionally made it as hard to open as possible!!! Between that and the cabin air filter.... sheesh! I could only get the larger side open (that you have to open first), and of course it's not the side with the terminals! Gah! I finally said screw it and I'm just hoping what I did with the S terminal/plug addresses the issue.
GGood is offline
post #17 of 18 (permalink) Old 11-04-2013, 04:07 PM
okellyr's Avatar
Yea my little black box got completely destroyed by me while trying to open it lol ..... Serious pia but it fixes the issue
Boosted baby....
BOOSTED
okellyr is offline
post #18 of 18 (permalink) Old 07-07-2017, 12:28 PM
Originally Posted by okellyr View Post
I had a similar issue recently and tracked the issue back to the starter positive cable... If u trace it from the starter backwards about midway across the engine it entered a black plastic box and the continues on to the battery ... Inside the box the cables are crimped down together ( completing the connection to positive ) ... The connections in there were not 100% ( corrosion ) I hit the connections with a terminal cleaning solution ( May have user the maf cleaning stuff ) and tried to tightens up the connections but they are super awkward to get to... No problems since then
Don't know I this is ur prob but it sounds similar
Ps like u everything would light up but no crank .. I found the issue in a moment of desperation and wiggled the cables = car started ... Wiggled again car no start ... Wiggled again = car started ... Not being the brightest I kept on testing until I was 110% sure that the cable I was poking was the right one ....
Thanks so much for this post okellyr, had this exact issue and I managed to start my car by messing with the wires with jack handle, I'll have to get under and fix it more permanently, but this post saved me a huge headache.
HeihachiMishima is offline
LinkBack to this Thread: http://www.mazda3forums.com/109-powertrain-technical-information-faqs-how-tos/560666-car-wont-turn-over-fixed-cable-connection-starter-janky.html
Powertrain Technical Information, FAQ's, How-To's [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 03-22-2017 01:53 PM
car won't turn over tsaigao Stock Issues 6 02-17-2011 11:10 PM
Cheap OBDII reader? hadacivicsi Powertrain Technical Information, FAQ's, How-To's 8 03-02-2009 01:17 PM
Car Won't Turn Over 110100100 MazdaSpeed 23 09-12-2007 01:01 AM
Who has OBDII reader in jersey area. droyal Northeast 1 02-20-2006 08:02 PM
Way to show DTC's without OBDII reader? MakeItSo Mazda3 (Axela) 0 04-26-2004 02:35 AM
