Phil Rab, owner/installer for Rab Designs Car Audio in Mandeville, LA
Current Mods:
JBR Stage 3 (RMM, shifter plate, shifter bushings)
ROCA OEM style (solid rubber) Passenger Motor Mount
Koni STR.T struts/shocks, speed3 RSB, Michelin Pilot AS3 tires 205/50/17 (stock size.)
MotorCraft XT-M5-QS in the trans(here for where I got mine)
Eonon D5151 w/ ebay backup camera Kenwood KDC-X997 + Infinity 6.5" components and coaxials + JL 320.4 + Sundown SA12/Rab Designs ported enclosure
Stubby Antenna
Spin on filter conversion
Aluminum AC knobs (ebay)
Ebay Flip Key with OEM blank installed (break out the hacksaw and file) starts at post#50 - de-modded cause the dealership cut my key some jacked up way, would start the car, but wouldn't unlock the door. Kinda became an issue when my remote battery died.
Door edge guards and badges removed (the easy ones at least)
Lamin-X yellow fog overlays and independent fog mod how-to
DIY SRI/converted stock air box and resonator delete
Painted shifter trim (looks classy, not ricey)1 2 3
JDM Axela badge
Redline Leather Goods shift boot, e-brake boot, console lid cover
TRS 5000K HID retrofit
Phil's AC Hell Thread http://www.mazda3forums.com/showthread.php?t=475618&highlight=
Phil's Shop thread/Rab Designs Car Audio builds and work in progress http://www.mazda3forums.com/showthread.php?t=647202&highlight=
Old Miata videos, I still miss this car.
http://www.mazda3forums.com/showthread.php?p=9096490#post9096490
I was mainly a lurker in the dark days of owning my 2005 hatch with the automatic. Now, with my 2007 hatch with a proper stick shift, the mod bug has bit once again
This build is going to be a balancing act for me. I commute a hundred miles a day for work, so comfort is priority one. I also bus my daughter around, so add safety to that. I'm also paying down a mortgage(translated as dirt poor most of the time). So, must be quiet, comfortable, and cheap; I know, I like a challenge.
My mods to date are pretty sedate. An Eonon D5151 sits in the dash. I did some work making custom wallpapers for it, and changed the GPS software to iGo Primo 2.4. Down the road, I may look into a backup camera and a small sub, but nothing crazy.
Under the hood, its all factory other than a spin on oil filter conversion and a James Barone Racing stage 3 kit (rear motor mount, shifter plate, and shifter bushings). The gear box is loaded with Redline MT90 and 5w-30 Mobil 1 in the engine. When time allows, I'll start looking into a fiberglass duct to channel cool air from the grill into the factory airbox, a DIY ram air.
Suspension is pretty open. Priority one is ditching the junk tires for something stickier but good for a daily driver. I'm thinking something from BFGoodrich, but I'm open to suggestions. I'm not sold on lowering the car since I drive some awful roads to work, but a rear away bar is probably in my future along with some paintwork on the factory wheels.
It's been a long intro, and I'll try to keep motivated in the face of keeping up with my family and work life. I'm also hoping some of my DIY work will benefit others here to repay the help I've received over the years.
Sent from my iPhone with Tapatalk.
Current Mods:
Stubby Antenna
JDM Axela badge
