Eonon D5151 Review/Q&A - Mazda3 Forums : The #1 Mazda 3 Forum
Old 03-19-2013, 06:35 PM   #1
armanrus
Grand Am Series
Default Eonon D5151 Review/Q&A
Reviews by others:
Alejandr0
Jamesberkey
Tutorials:
How To Change Info on Upper LCD for CAN-BUS equipped cars
Hi guys,
I received and installed my D5151 yesterday and here are my initial thoughts. As of this post, the car is in the dealer doing warranty work so pictures will come tomorrow or the day after. PICTURES ARE UP.
Installation and Compatibility
Installation was a breeze like the D5102. The only difference is that you have to screw in the clips that hold the bottom of the unit yourself but it was not a big deal. Also there are more wires at the back of the unit due to the CAN-BUS box so arranging the wires might be tricky (honestly the longest part of the install).
The unit is now totally compatible with the stock BOSE system, no more hacking up wires and splicing them. Also, since there is now the CAN-BUS decoder, the upper LCD screen now works. It will display whatever menu in the D5151 you are in (Home, Radio, GPS, etc). You will still need to do the install trick for the stock info (MPG, Miles remaining, etc) to be retained but otherwise it functions perfectly.
Sound
I don't consider myself an audiophile but the overall sound is improved over from the stock. This is a very subjective area so I will not really dive much into it, but it is an improvement over stock.
Features
I won't cover everything the unit has (which is a lot), but just the main points that is attractive for me.
Here's how the home screen looks like:
Here's a couple of the BT and BT Music:
Bluetooth works flawless. The BT music option is now integrated into the BT menu so don't panic if you don't see it at first. Connection to a device is much easier as the unit will now show you what PIN to use. The layout of the screen is also well-thought out. BT Music works great, just like the old unit. Only negative to report here is that I can't figure out yet how to import my contacts into the unit. I have a Galaxy S3 so iPhone users might not have the same trouble as me.
Here's the new radio interface:
Super improved radio interface over the D5102. The preset buttons are now at the top of the screen, and the unit now has a digital slider with a graph so you can just drag your fingers thru the screen to scroll through the channels. 3 FM modes, 2 AM modes. I haven't played with the RDS system yet so no comment on that for now.
A couple of the GPS and its menu:
Not much to say about the GPS other than it does it's job. I had Garmin installed on my D5102, but unfortunately I lost the SD card with it. I am going to try and make it work with the D5151 again.
The D5102 received an update wherein if you're using both the GPS and music, the music will not cut out when the GPS "speaks." That swayed me from getting a new D5102 after I sold the old one I had when I totaled my car. Not a problem with the D5151. There is a setting now that will let you choose if you want the music to play with the GPS, or have the front speakers turn off every time the GPS voice comes on. And if you do select the mixing option, you can change the volume ratio between the two. Nifty!
The reverse camera mode will now work automatically when you shift into reverse, unless you turn that feature off in the settings. Very handy because you now don't need to search for the 12-volt reverse wire and tap the signal wire to it. Turn the setting off when you don't have a camera installed.
You can now choose between 7 LED colors. Awesome for those with different LED's in their dash, but the amber is a perfect match with the stock cluster. You can also change the background wallpaper of the screen.
I have not tried the iPod interface yet because I don't have any iDevices anymore and the unit won't let you access a mode when it detects that there is no signal from that mode.
The unit also has a TPMS function that will work with the sensors that Eonon is selling. But right now, they are only offering sensors that have a frequency of 433Mhz. Our cars have a 315Mhz system. So if you have the OEM TPMS and you switched to Eonon's, you will have the warning light on all the time in your gauge cluster. It would be awesome if Eonon will make a 315Mhz system so we can keep the stock system still working.
One thing to mention is that this unit is significantly faster when loading. When you switch to the reverse camera on the old D5102, it will take a couple seconds for the unit to switch. The D5151 will do so in an instant. Navigating the menus is also a lot faster and fluid. Also, the unit will now auto-dim when it senses that you are using your headlights.
Conclusion
For the price, you can't beat this HU. Looks like it came from the factory, and the features are great. Worth every penny. If you are looking for an upgrade over your stock headunit, this would be something that is worthy to look at.
PROS:
-Super affordable and packed with tons of features
-Easy installation and OEM-look
-Very nice graphic user interface
-Very fast response when switching modes except for GPS which needs to load from SD card
-Fully functional upper LCD screen for those with CAN-BUS systems
CONS: (not really, more like suggestions)
-315MHz TPMS system to accompany our cars
-included GPS software could be better
2007 Mazdaspeed3 GT
armanrus is offline   Reply With Quote
Old 03-19-2013, 07:15 PM   #2
miata gt
Short Track Racer
miata gt's Avatar
Default
Nice. Thanks for the review!
Mark
2005 Mazda3i 5spd
1999 Rotrex Supercharged Miata @ 14psi
To a man with a hammer, everything looks like a nail.
miata gt is offline   Reply With Quote
Old 03-19-2013, 08:09 PM   #3
jamesberkey
Go-Kart Driver
Default
Thanks for the review. Looking forward to getting mine!
How do you do the "install trick for the stock info (MPG, Miles remaining, etc) to be retained?" Just for reference when I install mine.
Thanks!
2007 M3 sedan 5spd standard
1981 Chevy Malibu 3spd standard
jamesberkey is offline   Reply With Quote
Old 03-19-2013, 08:30 PM   #4
armanrus
Grand Am Series
Default
First you need to turn your key to the ON position. Then with the stock radio in place choose the info you want to be displayed. Then start the install, but don't turn the key and don't unplug the harness on the back of the LCD.
I think 04-06 models have a different design, ie their LCD screen does not have its own harness. If that's the case I would not know what to do as I have an '07.
2007 Mazdaspeed3 GT
Old 03-19-2013, 09:47 PM   #5
Jmdadams
Moped Rider
I don't know if you had this problem but I had a very hard time attaching the LCD to the D5151 I wasn't able to screw it on because if I did it was tilted down so right now it's sitting in there with no screws
Sent from AutoGuide.com Free App
Jmdadams is offline   Reply With Quote
Old 03-19-2013, 09:50 PM   #6
armanrus
Grand Am Series
Default
I did not have any problems. I think it is supposed to be tilted down. There are two slots on the bottom on both sides of the LCD that will mount onto the brackets provided by Eonon.
Also, I updated the first post with pictures and additional review.
2007 Mazdaspeed3 GT
Old 03-19-2013, 10:19 PM   #7
Jmdadams
Moped Rider
Ya I found those and when I screwed it in and installed it there was a lot of silver showing from the frame of the LCD but I jimmy rigged it and it looks fine haha
Old 03-19-2013, 11:48 PM   #8
mikeilo02
Moped Rider
Default
I beta tested the unit and I agree on the positioning the wires was the hardest part of the install! Haha
mikeilo02 is offline   Reply With Quote
Old 03-19-2013, 11:50 PM   #9
armanrus
Grand Am Series
Default
I'll be unmounting mine tomorrow to set the info screen lol, gotta go through it again. I'll take pics.
2007 Mazdaspeed3 GT
Old 03-20-2013, 12:06 AM   #10
Oshiguru
Short Track Racer
Default
I finished the installation of mine! I'm surprised because I didn't get instructions but things looked straightforward when I took things apart. Can you PM me a PDF/link to the installation guide?
Did you receive stickers to cover the transport screw holes? I just put a square piece of scotch tape over the holes.
Anyway, the installation was a breeze! I found a good spot to tuck the wires/can-bus box/and ipod cable. I don't have any pics as its dark now but I'll take my camera tomorrow and take a few shots.
Also I had no idea what to do with #1 and #2 on the top diagram, and the black plug on number 6 for the second diagram
http://www.eonon.com/UserFiles/image/D5151-06.jpg
Oshiguru is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > 2004-2009 Electronics Discussion
Similar Threads
Thread Thread Starter Forum Replies Last Post
Navigation for Eonon D5151 SurfinGorilla Eonon car DVD, audio, stereo, GPS, monitor 11 11-23-2014 07:04 PM
FS: Eonon D5151 $200 thiswho For Sale | M3F 2 06-17-2013 09:39 PM
FS: Eonon D5151 alexlod For Sale | M3F 3 05-20-2013 04:28 PM
Eonon D5151 Wallpaper mazdadragon3 2004-2009 Electronics Discussion 20 05-13-2013 03:25 PM
Eonon D5151...Why? Disciple 2004-2009 Electronics Discussion 10 04-08-2013 08:17 PM
