Control arm and motor mounts need replacing? - Mazda3 Forums : The #1 Mazda 3 Forum
Old 09-03-2012, 10:37 AM   #1
silver3i
Grand Am Series
Default Control arm and motor mount problems
went dealership for oil change.
they noticed lots of vibration in engine. (i thought i just needed new spark plugs since i'm pushing 125k on my Iridiums.)
passenger (top) motor mount is bad. he pushed on the seal and there was nothing there. $350 total.
he also said the rear (bottom) motor mount is damaged altho i dont see it. $250.
and the passenger front control arm is separating. I see the bushing damaged. $375
i said yes on the control arm ($200). labor is 1 1/2 hrs @ $108/hr.
what about the motor mounts? what happens if i dont fix it?
2005 Mazda 3i automatic (10/04 build date), Silver, 16" alloys (Toyo) - Works fine in medium rain
silver3i is offline   Reply With Quote
Old 09-03-2012, 11:40 AM   #2
XCNuse
Administrator
XCNuse's Avatar
Default
Motor mounts are super easy to do if you or a friend have tools and a jack.
You can buy an OEM passenger mount for .. I think it's around $70 or less from the dealership, and I'm not sure what the rear one OEM is at a dealership but probably also near $100
Labor time?
Well once you get the car in the air and the belly pan off, the passenger mount takes no more than 15 minutes (seriously... it's just 2 screws and 2 nuts).
Typically the passenger mount blows out around 60k, so I'm sure it's been dead for a long time and certainly would need replacing!
The rear one also shouldn't take long either, it's only two screws and a nut.
As for the control arm.. yeah, I've never done one of those, I'd leave that to the dealership.
'06 Whitewater Pearl build | the noob thread
XCNuse is offline   Reply With Quote
Old 09-03-2012, 11:55 AM   #3
silver3i
Grand Am Series
Default
Labor time?
for the passenger MM, why do i need the car in the air?
it can be reached from the top of the engine.
also, what happens if i dont fix the motor mounts?
it looks more like a cushion???
so the car will just vibrate a little? kindqa like permanent rough idle even in motion?
Old 09-03-2012, 12:16 PM   #4
XCNuse
Administrator
XCNuse's Avatar
Default
well.. okay I guess you don't have to lol, my car is to low to fit a jack under it, but for the rear you'll probably have to have the car raised up and then need a nice big 2x4 to move the engine (and certainly will need help)
I'm not sure what worst case scenario is of them not being replaced and I'd hate to find out... and for the low cost of replacing it yourself there is no need to not replace them.
Worst case scenario would be something breaks.. and I'd hate to find out what the consequences of that are.
Old 09-03-2012, 12:35 PM   #5
arsprod
Grand Am Series
arsprod's Avatar
Default
You can drive with blown passenger mount forever. I didn't even check mine until I got really bad wheel hop under 'sprited' driving (I was at the track). Rear mount I'm not sure, but given its design I imagine you'd start to get some clunking. If you don't drive hard you might be good. But, given that both are really easy to replace (especially with all the walk throughs on this forum) seems like not doing it would just be... well, lazy!
I am the Stig... Corksport SRI, Sure Torq R3, Sure BSD, JBR short shift plate, Eibach Pros, Koni yellows, Hotchkiss rear sway, EBC Yellow Stuff, Hankook Ventus RS-3 (track)
arsprod is offline   Reply With Quote
Old 09-03-2012, 03:53 PM   #6
silver3i
Grand Am Series
Default
Quote:
thx!
what would have happened if i didnt replace the control arm bushing (which is separating)?
Old 09-03-2012, 04:40 PM   #7
XCNuse
Administrator
XCNuse's Avatar
Default
Steering would go to shit, your tires would get destroyed and .. actual bad things would happen lol
You SERIOUSLY shouldn't be considering not fixing these things; motor mounts and control arm bushings are MAJOR components of a car.
Seriously think about it.. motor mounts hold the motor in place.. surely that is important right..?
Control arm bushings.. even the word control arm gives you some direction that it's important on a car.. right?
You can replace all of this yourself for a few hundred bucks (although i wouldn't want to do the bushing myself), and can extend the life of your car, and if you sell it it will raise the value considerably.
That or let them deteriorate, your motor clunk out of place, torque something, twist something else, control arm bushing fall apart and the control arm itself bend out of place, you swerve off of a highway at speed taking a few people with you and .. well.. all for saving a few hundred bucks? Not anymore...
(Would that honestly happen? Probably not... but it gives a fair reason why saving a few dollars on important parts.. isn't worth it)
Old 09-03-2012, 08:21 PM   #8
d.z.
Grand Am Series
Default
Not fixing those things is not an option. Start saving - Ramen Noodles is always an option if you are financially challenged.
Bicycle, bicycle, I like to ride my bicycle!!
2010 Pinarello FP3
2007 Quintana Roo Seduza (SOLD!!)
2005 Giant OCR1 (SOLD!!)
d.z. is offline   Reply With Quote
Old 09-04-2012, 06:25 PM   #9
silver3i
Grand Am Series
Default
wtf.. a control arm bushing is $10?!
and the dealership charged me $200 +1.5hrs labor @$100/hr
http://parts.arlingtonmazda.com/prod...2d156B%29.html
and i didnt get any lube for my butthole
Old 09-04-2012, 06:49 PM   #10
XCNuse
Administrator
XCNuse's Avatar
Default
Now go do all the work yourself and yeah.. you'll save a crapload of money..
(this is ALWAYS the case)
But have fun pulling off a control arm and pushing the old bushing out and pressing the new one in place.
Similar Threads
Thread Thread Starter Forum Replies Last Post
WTB Motor Mounts mxrider14 WTB General 2 08-21-2012 03:15 PM
replacing lower control arm bushing zoomzoom9 Suspension / Brakes 8 06-18-2012 12:14 AM
Motor mounts Mentalfloss Stock Issues 2 06-21-2011 08:36 PM
motor mounts pinkcheese Modifications 0 11-30-2009 06:52 PM
motor mounts slaterracing Steeda Autosports 3 09-13-2007 04:40 PM
