Squeaking noise Mazda 3 2010??? - Mazda3 Forums : The #1 Mazda 3 Forum
Old 05-29-2012, 09:32 PM   #1
Notorious TDA
Moped Rider
Default Squeaking noise Mazda 3 2010???
I have this strange squeaking noise (similar to the sound my bed makes when im humping the gf) while i press the gas pedal, or when the car hits a small bump.
DOES ANYBODY KNOW WHAT THIS IS?
Maybe i should make a video to help?
Notorious TDA is offline   Reply With Quote
Old 06-09-2012, 09:51 PM   #2
chubbs
Grand Am Series
Default Re: Squeaking noise Mazda 3 2010???
haha I have a squeaky sound too.. it seems to be caused by the rear seat latch or something. Mine only seem to happen when going over bumps.
2011 Mazda3 S GT
|OEM All Weather Mats|OEM All Weather Cargo Tray|TRS Morimoto Elite HID 4300K|K&N Typhoon SRI|CorkSport Interior LED Kit|MS3 ABE|
chubbs is offline   Reply With Quote
Old 06-09-2012, 10:18 PM   #3
itstillruns
maybe stop humping the gf in the car?
itstillruns is offline   Reply With Quote
Old 07-05-2012, 04:58 PM   #4
Notorious TDA
Moped Rider
[quote author=chubbs link=topic=210460.msg4238233#msg4238233 date=1339289485]
I dont think its that...... sounds like its coming from under the hood....
You can hear it from the outside.
I was even riding in a friends car and while we were pulling up to another mazda 3, it was making the same noise!
Its really annoying and loud as fuck.
I think i might just take it to the dealer, its almost at 60,000 prolly needs some tune ups
Old 07-10-2012, 02:54 AM   #5
deathwarden5
Grand Am Series
Without hearing it, I would suspect No.4 engine mount. They have a tendency to make a squeaking/creaking noise on 2010+
deathwarden5 is offline   Reply With Quote
Old 07-16-2012, 11:13 PM   #6
Notorious TDA
Moped Rider
ok im gunna make a video. How would i fix that problem?
Old 07-19-2012, 11:34 PM   #7
deathwarden5
Grand Am Series
Under warranty it's a straight replacement. You could try removing it, cleaning it and lubing it with something like SilGyde.
Old 08-07-2012, 01:25 PM   #8
cyborg_rat
Moped Rider
ya . I know what noise you are talking about, a lot of the mazda 3 2010 even 11 , have that sqeaks ironically my friends gf mentioned it this weekend asking me if i knew, On my street alone their is about 4 mazda 3 , some sedan like mine and 2 are hatch back same sound... and if you go the dealer they will denies it . It seems to be coming from the engine mounts i raised the car at a friends shop and the engine was running and it squeaked ..so car not moving..and not on suspension...limits the possibilities and that would also explain dealer denial .. because they would have to pull the engine out.if it where a belt or a bearing .. they would need to change it and would be easier
anywho thats my tough on it and I wish their was a easy solution ...well actualy :P i have one . dropped a sound system in and voila WHAT SOUND?
cyborg_rat is offline   Reply With Quote
Old 08-07-2012, 05:13 PM   #9
whisenhunter
Grand Am Series
I had this issue when I was going over small bumps, however it was more of a creak than a squeak. Turned out the front control arm bushings were shot and needed to be replaced. The dealership finally replaced them under warranty after replacing the front sway bar bushings, rear motor mount and transmission mount.
There is a TSB out there for this problem on the CX7.
whisenhunter is offline   Reply With Quote
Old 08-14-2012, 12:27 PM   #10
chubbs
Grand Am Series
found out the squeaky noise i had was coming from the 3rd brake light cover. wasn't on all the way to it was squeaking. snapped it back in tight and no sound.
2011 Mazda3 S GT
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Powertrain for 2010-2013 > Stock Issues
