18x9.5 wheels on Mazdaspeed 3 (2008.5)? - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
Old 01-18-2012, 10:21 PM   #21
kradios
Moped Rider
Default Re: 18x9.5 wheels on Mazdaspeed 3 (2008.5)?
I have 18x9.5 +35 so you should be fine
Sent from my Desire HD using Tapatalk
kradios is offline   Reply With Quote
Old 01-19-2012, 02:06 AM   #22
lax22pearl
Send a message via AIM to lax22pearl
[quote author=kurupt link=topic=202396.msg4175354#msg4175354 date=1326937423]
[quote author=lax22pearl link=topic=202396.msg4175351#msg4175351 date=1326936824]
roll, 3mm spacer to clear strut, and around -3* camber should do the trick. and yeah will look ridiculous at stock height or even just lowered on springs. oh and i run a 215/35/18 on my 18x9.5
Thanks, that's really helpful to know! What offset are your wheels? And wouldn't the spacers make the wheel stick out even more than needed?
front is 18x9.5 +22 rear is -3. and yes but you may need it to clear strut. as stated above i know a +35 will clear but idk about a +38. thats why a 3mm spacer will do the job perfectly
lax22pearl is offline   Reply With Quote
Old 01-19-2012, 11:57 AM   #23
exentix
exentix's Avatar
just a thought.. you are talking about clearing the strut, but lax, arent you on coils? hes on stock suspension. ive heard the stock struts are way beefier than coils. might need a bigger spacer to clear then correct?
JAMES BARONE RACING
jbr stuff, cp-e catted dp, autotech cdfp internals, cobb ap, cobb xle bpv, grimmspeed ecbs, STRATIFIED TUNE in progress, enkei evo 6, continental dw, 35% tint
exentix is offline   Reply With Quote
Old 01-19-2012, 02:08 PM   #24
kurupt
Go-Kart Driver
[quote author=exentix link=topic=202396.msg4175634#msg4175634 date=1326992249]
^ that's true that im on stock but when i drop, ill be on coils also. or are you worrying that before i drop, it will be a problem?
kurupt is offline   Reply With Quote
Old 01-19-2012, 03:07 PM   #25
a-sher
Send a message via AIM to a-sher
Drop first, wheels second.
a-sher is offline   Reply With Quote
Old 01-19-2012, 06:27 PM   #26
dnick454
Go-Kart Driver
Curious what coilovers you run that 9.5 +38 wont even clear. I fit a 17x9 +48 on and it clears the strut by a credit card. That would mean a 9.5 +40 would fit the same if not a little more room so 9.5 +38 should clear pretty easy. You need a spacer ontop of that though?
2010 Mazda3i Touring - Liquid Silver
dnick454 is offline   Reply With Quote
Old 01-19-2012, 07:11 PM   #27
sdemo45
Your average forum a**hole
sdemo45's Avatar
Default 18x9.5 wheels on Mazdaspeed 3 (2008.5)?
tire size matters. I couldn't clear 8.5 +48 with 245s.
sdemo45 is offline   Reply With Quote
Old 01-19-2012, 07:30 PM   #28
lax22pearl
[quote author=dnick454 link=topic=202396.msg4175831#msg4175831 date=1327015658]
not me but another guy with BCs and 18x9.5 +35 says it is super close. idk exactly how close casinos it's not my car but going off of what I've heard/read
Old 01-19-2012, 08:45 PM   #29
kradios
Moped Rider
Default Re: Re: 18x9.5 wheels on Mazdaspeed 3 (2008.5)?
[quote author=lax22pearl link=topic=202396.msg4175849#msg4175849 date=1327019406]
That was me, and yes its very close, I had to use a 215/40 tire, a 225 wouldn't fit.
Old 01-23-2012, 06:04 PM   #30
kurupt
Go-Kart Driver
so how dangerous is it to drive a 215/40/18 stretched on a 18x9.5? i do like stretched tires but i dont want them to be so thin that it can easily pop if u hit a pothole or nail.. should i be worried much and consider going to 225?
and if i do choose 225 over 215, will it be a problem to put 225/40/18 on the MS3 stock rims (normally wears 215/45/18)?
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Wheels / Tires
