fuel pump replacement how to? - Mazda3 Forums : The #1 Mazda 3 Forum
Old 10-30-2011, 07:54 PM   #1
lo1antman
Short Track Racer
Default fuel pump replacement how to?
does anyone have a how to on the fuel pump or any pointers before i start tackling this task? thanks
lo1antman is offline   Reply With Quote
Old 10-31-2011, 09:52 PM   #2
pinkcheese
Senior Member
Default Re: fuel pump replacement how to?
Get one from the junkyard. I have looked around and parts stores only sell the basket as a single unit not just the pump. Depending on the year of car and emissions protocol could range from $300-$450
also getting to the fuel tank isn't hard jsut make sure when you go to unlock the pump from the tank push down otherwise the child lock will kick in and you will just free spin the pump in place.
pinkcheese is offline   Reply With Quote
Old 11-01-2011, 01:17 AM   #3
lo1antman
Short Track Racer
ok thanks for the pointers and also one more thing, i have to drop the fuel tank to get to the fuel pump right?
Old 11-01-2011, 10:08 AM   #4
pinkcheese
Senior Member
yes
Old 11-01-2011, 10:47 AM   #5
ekanddsm
To make the job easier, have the tank as empty as possible, otherwise your gonna make a mess.
There are two different styles of fuel pump depending on if you have a plastic tank or a metal one. The metal one has a little slide ring that only requires a screw driver and a hammer to remove.
Make sure you pull the rear seat cushion up and disconnect the fuel pump connector.
So you have a fast______(your cars name here)????
ekanddsm is offline   Reply With Quote
Old 12-17-2011, 11:29 PM   #6
Jolo
Moped Rider
For a step by step procedure on how to replace the fuel pump, go to: http://www.4shared.com/folder/tF1dpg9H/_online.html and download the PDF file. I put together this doc when I replaced mine.
Hope this helps.
Jolo is offline   Reply With Quote
Old 12-21-2011, 02:12 PM   #7
Eighty8
Go-Kart Driver
Send a message via AIM to Eighty8
Do the regular 3's have a CDFP as well? Or just a fuel pump in the tank?
2007 True Red Mazdaspeed 3
Fujita CAI / Cobb AP / Cobb TIP / Cobb DP / Autotech HPFP Internals / Turbosmart Dual Port / Sure SSP / Sure SSB / Sure RMM / JBR EGR BO / Spin-On Oil Filter / Whiteline BSC / Whiteline Castor Kit / Kumho Ecsta SPT
Eighty8 is offline   Reply With Quote
Old 12-21-2011, 03:37 PM   #8
dugger_8
Moderate your face
dugger_8's Avatar
Just a pump in the tank.
Wagon Mafia ~~~ wM Swag ~~~ For Sale
dugger_8 is offline   Reply With Quote
Old 05-01-2014, 04:28 PM   #9
eljean
Grand Am Series
eljean's Avatar
Default
Quote:
Originally Posted by pinkcheese View Post
yes
Do you have to lower it even if you're replacing the entire fuel pump assembly?
eljean is offline   Reply With Quote
Old 05-01-2014, 05:31 PM   #10
okellyr
Senior Member
okellyr's Avatar
Send a message via MSN to okellyr
Default
Yes, the assembly can only be accessed by dropping the tank
Sent from my iPhone using Tapatalk
Boosted baby....
BOOSTED
http://www.mazda3forums.com/showthread.php?t=400303
okellyr is offline   Reply With Quote
