Driver and passenger front windows will not move - Mazda3 Forums : The #1 Mazda 3 Forum
Old 10-11-2011, 08:15 PM   #1
GreyKiller2005
Send a message via AIM to GreyKiller2005 Send a message via MSN to GreyKiller2005 Send a message via Yahoo to GreyKiller2005
Default Driver and passenger front windows will not move
About two weeks ago, the right front window stopped going down. I drive alone, so I did not think much of it. Then today, the driver side does not go down. The left and right rears go down and up just fine.
I push the driver side and passenger side front, and I hear a click come from the door, but the window does not move.
The fuses appear to run l-l and r-r so it cannot be a fuse problem.
Bad relay? bad motor?
Any ideas?
....and yes I tried "search" a couple of times and all I get are threads about the double click issue that happens when you unhook the battery. This aint that.
Any help would be appreciated.
The Defiant has new pictures from night shoot, and you can see my ugly ass mug at:
http://www.cardomain.com/ride/813652
Check out The Defiant at Sunrise:
http://www.cardomain.com/ride/813652/7
and... http://www.facebook.com/album.php?aid=25856&id=100000896726475&sav ed#!/album.php?aid=25856&id=100000896726475&pag e=3
GreyKiller2005 is offline   Reply With Quote
Old 10-11-2011, 09:50 PM   #2
Carowen
Default Re: Driver and passenger front windows will not move
take off the door panel and have a look.
|Bc Coil-Overs|SPC Rear Camber Kit|8k HID Lows and Fogs| 7k Angel Eyes| 17x7.5 Speedy Lite-Fin Wrapped in 225/45/17 General Exclaim UHP| Custom Interior- Painted pillars, Door panels two Toned Black and Red Suede, Black Leather Headliner|
Carowen is offline   Reply With Quote
Old 10-11-2011, 09:55 PM   #3
tjb1
Push down on the window while working the motor, mine get stuck because the weatherstripping gets stuck to the window. They were actually stuck at the dealer when I got my car.
2008 Mazda 3 2.0
[img width=222 height=100]http://www.speedtest.net/result/1278529798.png[/img]
tjb1 is offline   Reply With Quote
Old 10-12-2011, 05:12 PM   #4
ForestGrump
Short Track Racer
Does it roll down if you use the buttons on the driver side door? If it does, then it's prob the switch in the driver door.
Do the lights dim when you hit the switch? If yes, then motor is drawing current. If not, maybe not with the motor.
I am currently having a problem with the passenger rear window not rolling down (thankfully it will go back up tho). It's the switch in the driver door. blargh I'll have to open the door to clean the switch/contacts.
01 Honda Insight 26k mi -- Rear ended by Ford Exploder
03 6i MTX 96.6k mi -- SOLD!
09 speed3 GT 78kmi
ForestGrump is offline   Reply With Quote
Old 10-12-2011, 08:18 PM   #5
GreyKiller2005
Window will not roll down using either switch. Lights dim when I hit the switch for either door. Try to push window down, will not roll down.
Thought maybe a bad relay but that does not make much sense...since the fuses are for left-side, right side, the relay must be as well.
Two motor failures?
I only ask because when I get the car apart, I will not be able to drive it (cops hassle you when you have loose pieces on the car--don't ask), so I would like to have the necessary parts on hand.
Can you get the window motor all by itself? I thought of pulling the motors from the back windows...
Old 10-12-2011, 08:21 PM   #6
tjb1
If lights dim, the windows are probably stuck. Try to run a credit card or something between the weather stripping and window on the inside of the car.
2008 Mazda 3 2.0
Old 10-13-2011, 12:00 AM   #7
GreyKiller2005
the weatherstripping was tight, but I was able to run the card all the way around on the inside. I can actually hear a soft clunk when I hit the door switch.
could not get it in the outside between the strip and the window will try again tomorrow...
Old 10-13-2011, 10:01 AM   #8
5port
Grand Am Series
[quote author=tjb1 link=topic=199656.msg4129259#msg4129259 date=1318384515]
This...
To prevent it every once in a while roll the windows down, saturate a q-tip with silicon oil (CRC,etc) and wipe the q-tip all the way around each window track.
Cobb SRI,RPMC TIP,HOEN Yellow,Kvent,Rotella T6
5port is offline   Reply With Quote
Old 10-13-2011, 12:01 PM   #9
tjb1
By the way, the motors are really easy. Take the door panel off and its connected to the window frame/drive sprocket by 3 long screws. Shouldnt need to touch it though if lights are dimming and all.
2008 Mazda 3 2.0
Old 10-14-2011, 03:32 PM   #10
GreyKiller2005
[quote author=tjb1 link=topic=199656.msg4129772#msg4129772 date=1318465307]
I used Blaster on both windows last night, spraying all arid the edges. This morning they were both stuck. At. Noon, the passenger window worked! Maybe that was the answer; I will spray more of the lubrication in the driver side door tonight to see what happens.
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > MazdaSpeed - Sponsored by StreetUnit > MazdaSpeed3 Stock Issues
