Thread Tools |
#1 |
Short Track Racer
My driver's door lock would not lock or unlock. I can see it trying but, it seems like the tiny toy car motor is on it's last leg, or the plastic gears are shot. The stealership wants over $100 bucks for it and on-line about $120. Have any of you had this issue before and how did you re-solve it?
| Sponsored Links | |||
Advertisement | |||
#2 |
Senior Member
the motor in mine burned out. i have not gotten around to fixing it. if you do take it apart document it please. currently i use the key and lever inside...
MS CAI - F2 CBE - ACT Flywheel - ACT Clutch - ACT Pressure Plate - MS 6 Speed Trans - TWM Desert Eagle Shift Knob - MS Springs - MS Shocks - MS Rear Camber Links - Techna-fit SS Brake Lines - Hawk HPS Pads - Cosworth BSD - Ported TB - 2.0L Oil Filter Conversion - LED Door Sills - Sharkfin Antenna - 35% Tint |
#3 |
Short Track Racer
After much re-search, i just ordered one from the stealership for $130 bucks.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
