ATF MV vs Dexron III - Mazda3 Forums : The #1 Mazda 3 Forum
Old 05-31-2011, 05:31 PM   #1
robtrevino
Short Track Racer
Default ATF MV vs Dexron III
Hi guys,
This question might have been asked a couple of times before, but the truth is I haven't been able to find a definite answer.
Is ATF MV equal to Dexron III?
'07 Black Mica 3s (Mexico)
'10 Gray 3i Sport (USA)
robtrevino is offline   Reply With Quote
Old 05-31-2011, 05:49 PM   #2
IBrakeForNobody
Default Re: ATF MV vs Dexron III
Short answer is probably not.
Longer answer is that ATF-MV is pretty close to Mercon V, except that ATF-MV has a higher anti-shudder property than Mercon V (I believe anyway, don't quote me on that). Dexron III is similar to Mercon, and Mercon is different than Mercon V, so Dexron III isn't probably a good replacement for ATF-MV.
IBrakeForNobody is offline   Reply With Quote
Old 06-01-2011, 04:50 PM   #3
robtrevino
Short Track Racer
the reason I ask is this:http://www.bobistheoilguy.com/forums...697&page=2
Please read the first post of that page
Old 06-01-2011, 05:42 PM   #4
IBrakeForNobody
Maybe I or that poster have different or outdated service manuals, but I wasn't able to find anything. This obviously isn't every document in the service manual that states the fluid type, but I read through the entire section and didn't find any special notes or anything.
[img width=352 height=768]http://img.photobucket.com/albums/v172/cayun/Mazda3/cf8098c5.jpg[/img]
Mazda did release a service bulletin regarding Mazda ATF-MV and Ford Mercon V, but it doesn't mention anything about Dexron III.
http://www.finishlineperformance.com...05-08-1928.pdf
Old 06-01-2011, 06:02 PM   #5
robtrevino
Short Track Racer
wow, cool. Thanks for the detective work.
Old 06-01-2011, 07:49 PM   #6
DrWebster
Moderator
DrWebster's Avatar
Our transmissions are fairly picky about fluid, and are certainly quite hard on it...I'd only use fluid that specifically says it's M-V compatible (not just Mercon V). Mobil 1 Synthetic ATF has worked quite well for many folks around here, myself included.
DrWebster is offline   Reply With Quote
Old 06-03-2011, 12:59 PM   #7
ryann
Short Track Racer
I saw this posted elsewhere on the forum, but this seems like a good place to post.
How about this fluid?
http://www.amazon.com/Red-Line-30504...825&sr=8-1
They have 4 and 12 packs available too.
I'd want to keep away from the Mazda Fluid, as it goes bad very quickly (at least the stock stuff did).
ryann is offline   Reply With Quote
Old 06-03-2011, 01:53 PM   #8
robtrevino
Short Track Racer
seems very expensive, specially since Mobil 1's is like 25% cheaper no?
Old 06-03-2011, 07:00 PM   #9
ryann
Short Track Racer
I have Mobil1 in my car right now. It's not the right kind, is it?
Old 06-03-2011, 07:05 PM   #10
DrWebster
Moderator
DrWebster's Avatar
[quote author=ryann link=topic=191508.msg4040283#msg4040283 date=1307142021]
If it's Mobil 1 Synthetic ATF, then it's just fine -- it's rated as being compatible with ATF M-V. I've been using it since I had 30k on the car, and the car has 82k on it now.
