it keeps stalling out - Mazda3 Forums : The #1 Mazda 3 Forum
Old 05-02-2011, 11:50 AM   #1
2008mazda32.0l
Short Track Racer
Default it keeps stalling out
Hey there all my car keeps idling extremely low and stalling out when I'm stopped or stopping is this the egr valve? Or is there something else goin on here thanks
2008 Mazda 3 2.0L mods: Custom SRI, Glow Shift guages, Straight pipe exhaust, OBX Racing Header and down pipe.
2008mazda32.0l is offline   Reply With Quote
Old 05-02-2011, 02:47 PM   #2
michaelallaire7
Default Re: it keeps stalling out
How does it start when after you fill up your gas tank? I had the same problems and it ended up being the purge control solenoid valve. Mazda replaced it under warranty.
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
michaelallaire7 is offline   Reply With Quote
Old 05-02-2011, 03:21 PM   #3
2008mazda32.0l
Short Track Racer
Honestly it does it whenever it wants lol its just random.. Sometimes it runs fine..
Old 05-02-2011, 09:28 PM   #4
outtadodge
Moped Rider
it's possible it's the exhaust gas recir valve but usually there is a c.e.l. associated with that.
maybe if you can be a little more specific, we can help diagnose it.
outtadodge is offline   Reply With Quote
Old 05-02-2011, 09:30 PM   #5
greeenie
Moped Rider
id pull codes if u have a cel, if not, id almost bet on the purge valve, it can cause lean conditions and low idle, this is becoming more and more common
greeenie is offline   Reply With Quote
Old 05-02-2011, 10:00 PM   #6
2008mazda32.0l
Short Track Racer
I'm not getting a cel ill start the car it'll idle fine then eventually start studdering and bogging down then eventually stall out and sometimes when I stop the rpms just drop and it shuts off. The only reason I tthink its the egr is that mazda told me it needed to be replaced before and I thought the dealership was just trying to choke money out of me.. So I never even looked at it
Old 05-02-2011, 10:54 PM   #7
greeenie
Moped Rider
its also possible u r having an issue with the IACV, which will never throw a code
Old 05-03-2011, 12:01 AM   #8
Vetrayed
Moped Rider
A lot of stupid stuff can go wrong and never throw a code, check you air filter, spark plugs, and make sure their is no oil on the spark plug boots. Run some good injector cleaner through it to clean your lines, and make sure their is no water in the system. All of these are $5 fixes, no problem.
Vetrayed is offline   Reply With Quote
Old 05-03-2011, 01:59 AM   #9
legionsk
Moped Rider
could be the fuel pump, had a similar problem years back with my old cavi. wouldnt throw codes, just pooped out whenever it wanted to.
legionsk is offline   Reply With Quote
Old 05-03-2011, 09:31 AM   #10
2008mazda32.0l
Short Track Racer
So I checked my cai and the coupling was lose from the throttle body so I tightened it and now it won't stall out but its still studdering and idling extremely low
