Thread Tools |
#1 |
Short Track Racer
Well got to gas station not much gas left and realized that the gas cap was stuck and gave it a good turn and it snapped in half. I looked around and see that this is a normal problem unfortunately have no gas in the car and dont want to go through the hassle with towing it or anything. I was just going to order a replacement cap but i was wondering if anyone had any tips on how to remove the cap thats stuck now. Here s a pic
![]() thanks
2009 CWP Mazdaspeed 3 -- Turbosmart BOV-Tenzo DC6-Tow Plate-Emblems painted -- |
| Sponsored Links | |||
Advertisement | |||
#2 |
Short Track Racer
Use a flat tip screw driver to turn it and take it out, then go buy a new one. Had this happen to a buddy of mine before.
#3 |
Maybe a set of needle-nose pliers could grab the "cross-thingies"
^And yes, that's a technical term.
Yes, I am a pirate, 200 years too late. The cannons don't thunder, There's nothin' to plunder, I'm an over-40 victim of fate |
#4 |
Moped Rider
I had this problem too, but I was very far from home/anything, and my response was a bit less reasonable than yours: I threw a hissy fit at the gas station and, in a rage, broke the cap into a dozen pieces with a pair of needle-nose pliers I had in the back. Then, of course, I got the emissions/gas cap check engine light, took it to the dealer and bought a new gas cap.
Just be careful when you're destroying the cap that you don't drop pieces into the tank. There is that metal flap that will catch pieces, but if you're not careful where you're sticking the pliers/screwdriver, you can accidentally push the flap in. Good luck! |
#5 |
use your man hands
-CoolGuy stickers, mad awesome bright lights, blackedout lenses, super wicked general tires I got from Sears for forty dollars, some random size shift boot, mad skillz shift knob with fake carbon fiber. This is the stuff you put in your sig when you have nothing done to your car but you want to feel kewl with your wire wrap and neon LED underdash lights. |
#6 |
Short Track Racer
took a while but carefully was able to get the cap off and just ordered a new one so hopefully wont take long to get here so i can start driving it again
#7 |
Location: Houston, but my mind is in a much better place
Just stick a rag in it like in the "olden days"
corksport SRI & turbo inlet hose, Viper Alarm, Pioneer AVH-3200bt, Cobb downpipe, access port, CP-E HPFP, Corksport FMIC http://www.mazda3forums.com/index.ph...129#msg4159129 |
#8 |
Moped Rider
A rag will stop the sloshing, but not the CEL. Get the new cap, drive with it for a few days and the CEL should turn itself off (did for me). Or you can take it to a mechanic and have them dismiss the code. Either way.
#9 |
DUCT TAPE!!! °
#10 |
I had this same problem on my 08.5. I got it out by using pliers and twisting it clockwise. It just kinda popped out. This is a problem known by mazda, and if your car is under warranty then I'm pretty sure they'll fix it for free with a redesigned, new mazda cap. Give your dealership a call and they should be able to help you. This was really the most pleasant experience I've ever had with my dealership. They just looked at it, yanked it out and gave me a new one. I singed a paper and was on my way.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
