HOW TO: Install Mazdaspeed3 OEM Front Brakes For 2.0L Owners - Mazda3 Forums : The #1 Mazda 3 Forum
Old 04-16-2011, 11:52 PM   #1
daustin
Default HOW TO: Install Mazdaspeed3 OEM Front Brakes For 2.0L Owners
Tools Needed:
- Floor Jack (If you have a lift, you are epic)
- Jack Stands (At least two)
- Ratchet
- 17mm socket
- Breaker Bar (Optional)
- 10mm wrench
- 13mm wrench
- 14mm wrench
- 7mm allen key (or allen socket)
- Hammer
- Clamp (C-Clamp or other large clamp)
- Empty Container for Fluids
Supplies Needed:
- Brake Fluid (I would recommend at least 32oz, the more the merrier)
- Brake Parts Lubricant
- 1/4" Inner Diameter Tubing (Optional)
- Plenty of Shop Towels
Parts Needed:
- Front Caliper, Left (B3YF-33-61X)
- Front Caliper, Right (B3YF-33-71X)
- Caliper Bracket x2 (B3YF-33-28X)
- Brake Pads (B3YF-33-23Z)
- Front Rotor x2 (B37F-33-25XA)
- Caliper Spring Clip x2 (B37F-33-233)
- Bolt, Upper x2 (9975-60-230)
- Bolt, Lower x2 (9YA0-2A-225)
Estimated Difficulty: 3/10
Estimated Time: 1.5-2 hours
Important Notes
- I performed this on my own vehicle. Please take caution when performing any types of maintenance or upgrades on your own vehicle. I am not responsible for any errors or damage caused to anyone's vehicle, property, or friends. If you are not comfortable working on brakes yourself, please leave it to the professionals.
- Always, ALWAYS, put the car on jack stands when lifting the vehicle off of the ground. There is no reason to not use jack stands. It does not matter how much of a hurry you are in or how limited your space is. If you can't put jack stands under the car, you should not be anywhere near it in the first place.
- I refer numerous times to the term "friend". Some people commonly have these around and others do not. No need to fear. One can usually obtain a person to assist easily with bribes of food, favors, or beer. This is not a job that will be easily done with only one person.
- This job requires bleeding and/or flushing the brake system. If you do not know how to perform this job, you will need someone who does know how to do so.
The Installation:
This is a relatively easy upgrade to do. If you have ever changed out brake rotors/pads on a car, this is just one more step beyond that. As far as costs are concerned, this is really only feasible to do if you can pick up most of the components used. I priced out the whole list of parts at the dealer and it was just shy of $2,000 for just the parts listed above with Mazda part numbers. I picked up my calipers from a local salvage yard for under $200 and only needed to go order the bolts to mount the brackets to the hub. All together, this project cost me about $350.
First, you will want to prepare your calipers. I chose to paint mine red from the luxury of my office at home.
You should make sure you lubricate the slide bolts. This is a very fast, simple, and easy step to do and one of the most overlooked when doing brake jobs. Usually brake lubricant is about $1 at any auto parts store and helps keep the efficiency and proper life of your brakes. Just spread a few dabs on each of the slide bolts and slide them back into the caliper. The rotation of threading them in will spread it around and through the hole.
Also make sure to reinstall your black dust covers over the slide bolts when finished. You want these to remain clean over time.
Once you are ready to begin installation, start with jacking up the car and putting it up on jack stands. I cannot stress how important it is to make sure the car is on jack stands before starting any work underneath of the car. After the car is jacked up and in place, you will need to take the wheels off. If you do not have access to air tools, you will want to break the lug nuts loose before jacking the car up.
Once you have your wheel off, you're ready to go. I immediately placed a plastic bucket behind the caliper ready to catch any stray brake fluid and any dripping while I switch the brake line from one caliper to the next.
The first step is to break loose the caliper support bracket bolts. This is where you will need your 17mm socket. This is usually much easier with a breaker bar, but a ratchet will work. Be careful, as these bolts are normally very tight. When they break loose, it is easy to slip and lose your grip, which is the #1 cause for smashing your hand into nearby suspension components. I forgot to take a picture of the back of the caliper while it was still mounted, so if you cannot find the bolts, they are directly at the top behind the caliper and the other is a few inches lower.
After you break the two 17mm bolts loose, do not completely remove them. It will make this next step easier.
The next part is to remove the brake line from the caliper. You will need your 13mm wrench and your 14mm wrench for this part. Caution is needed in this step. These bolts are very easy to round off. Make sure you have a solid grip on the bolt as you try to turn it. I almost rounded off one of my brake line nuts while I was doing this, but managed to stop myself before doing too much damage. It WILL feel like the bolt is turning while you strip the edges off, so please be careful.
Place the 13mm wrench on the nut closest to the surface of the caliper. This is the one you will turn. In order to prevent kinking and twisting of the brake line, place your 14mm wrench on the nut just above it to keep it steady.
Once you have completely removed the brake line from the caliper, allow the line to drip into your container. If you leave the cap on the brake fluid reservoir, the dripping will be much slower since air is not introduced into the system. Now you can go ahead and completely remove the 17mm bolts from the back of the caliper.
[img width=576 height=768]http://img20.imageshack.us/img20/9647/1000186md.jpg[/img]
This is where it's time to break out your BAMF (Big A** Mother F*****) hammer. This saved me quite a bit of work, especially considering I was not re-using any of the current brake components. First, tap the caliper towards the outside of the rotor. It will slide off very easily. Set your old caliper aside. Next, tap on the outer edges of the rotor to break it loose. This could take some "harder" tapping to break it loose initially. I had to all but slam it with a hammer to get mine loose after 92,000 miles of use.
Installation of your new Mazdaspeed3 calipers and rotors goes in the reverse of how they were disassembled. It only took me about 30 minutes for each side to remove and install the new components. A few tips and tricks that may help in installation:
- It was helpful to have a friend hold up the caliper in place while I aligned the bolts into the new caliper. The Mazdaspeed3 calipers are pretty heavy and holding it up then aligning the bolts is awkward to try and do alone.
- If your caliper does not want to slide over the rotor, you will need to compress the piston in the caliper so that the brake pads spread far enough apart.
- "Bench Filling" the caliper with brake fluid will speed up bleeding times later. Bench filling is where you put fluid into the brake line hole to fill up the piston in order to minimize the amount of air introduced to the brake system.
- Avoid getting brake fluid on your rotors and pads. This will prevent proper break in of your new pads and rotors, not to mention unsafe braking conditions.
Once you have your new brakes installed, it is time to bleed the brakes. Make sure you take the cap off of the brake reservoir and fill it up with new brake fluid. I had about 16-20oz drain out into the bucket during swapping calipers. You never want the master cylinder to run dry.
This is the point where you will need to bleed the brakes. Have one friend inside the car and the other person to go around to each wheel and bleed the brakes. Depending on how adventurous you are feeling, you can also bleed the rears while you are at it. The order to go by is to start at the rear passenger, then rear driver, followed by the front passenger and concluding with the front driver. You need to start at the caliper at the furthest point from the master cylinder and work your way closer.
I made the job of bleeding very easy by putting about a foot of 1/4" ID vinyl tubing onto the bleeder of the caliper and submerging the other end in the existing bucket of brake fluid. It made it easy to see the air bubbles pushing out and helped keep air from getting sucked back into the caliper. Also, I made sure a block was laid in the car behind the brake pedal to prevent pedal from traveling all the way to the floor. This was a precaution in case the reservoir went low on fluid and to prevent damage to the master cylinder.
A few comparison pictures I took with parts sitting on the floor of the garage.
2012 Black Mica Mazdaspeed3 - 308hp/341tq
| AT HPFP | Cobb AP | CP-e RMM/SRI/TIP/TMIC | H&R | JBR RSB/SSB/SSP | SPC | UR CBE/TP |
2012 True Red Mazda2 (Daily)
2006 Shimmering Sand Mica Mazda3 (Wife's)
daustin is offline   Reply With Quote
Old 05-07-2011, 10:42 PM   #2
chrislitz
Grand Am Series
chrislitz's Avatar
Default Re: HOW TO: Install Mazdaspeed3 OEM Front Brakes For 2.0L Owners
I think this deserves a sticky. You took the time to take the 1 month process from your other thread and compress it all into one tutorial. Looks great too. Good job all around
5000K HID Low-Beams, 2500K Noyka Fogs, LED Interior/License Plate, Chrome Turn Signal Bulbs (Parking Light Delete), Independent Fog Lights, Yellow Fog Light Lamin-x, 25% Tint, TB Ground, JBR Solid Shifter Bushings, 12" Rockford Fosgate Sub with Rockford Fosgate P300-1 Amp, MS3 RSB & Endlinks
chrislitz is offline   Reply With Quote
Old 05-07-2011, 11:03 PM   #3
daustin
[quote author=chrislitz link=topic=189424.msg4016764#msg4016764 date=1304818934]
I think this deserves a sticky. You took the time to take the 1 month process and compress it all into one tutorial. Looks great too. Good job all around
Thank you. I put a lot of time into this. Considering I see you are only in Allentown, if you ever want help or to see it for yourself, I am actually local.
Old 05-08-2011, 05:40 PM   #4
chrislitz
Grand Am Series
chrislitz's Avatar
No problem. And if I ever do decide to upgrade brakes I will definitely consider it. Thanks
Old 05-24-2011, 09:12 AM   #5
quantumphreak
Looking at your comparison shots of the calipers them selves. It looks like the pads and pistons are the same size it's just the calipers them selves which are bigger? I can't really tell from the picture...I was was talking to one of the guys in the service bay at my dealership about this swap out and he had told me That the internal working diameter of the pads and pistons are the same and it wasn't worth the switch over that I was just adding unnecessary weight to my car. He said if I were looking to gain stopping power that the brake system on the Rx8 R3 would be the way to convert to or just use a big brake kit...
That stuff coming out of your HUGE chrome exhaust you have mounted at an angle isn't power..It's Rice!!!
quantumphreak is offline   Reply With Quote
Old 05-24-2011, 10:04 AM   #6
daustin
[quote author=quantumphreak link=topic=189424.msg4031731#msg4031731 date=1306239161]
There was definitely a difference. I did not take my digital calipers to anything, but I can tell you both the pad and the piston were larger. The pad surface was not terribly larger, but it definitely was not as small as the OEM 2.0 pads. The caliper size is some ~10mm larger on the MS3 caliper than it was on the 2.0 ones. Not to mention the larger rotor with a much longer travel surface per wheel rotation. The extended track of the rotor surface alone will more surface area for friction, hence more "stopping power" if you will.
I mean, you have to ask this question. If the pad and the piston were both the same size between the 2.0/2.3 and the speed3, why wouldn't they have used the same calipers for all of the models? They did for the 2.0/2.3 with the calipers and pads as far as I know, but they upgraded the rotor diameter with a taller bracket for the 2.3 to compensate for the weight differences. Why wouldn't they have just done the same for the speed3 if they weren't utilizing the larger caliper for the ability to add a larger piston and larger pads? It just makes sense.
It wouldn't be the first time I have doubted advice given from a Mazda technician.
Old 05-24-2011, 10:13 AM   #7
quantumphreak
Like I said I can't see from the picture. I see the caliper difference but he was referring to the piston and pads I get the surface area equation. I want some serious eye fuck behind my wheel. I am looking at the big brake system replacement I just hate the price tag.
Old 05-24-2011, 10:18 AM   #8
daustin
Like I said, the pads themselves are not much larger, but it is a difference. The set of brand new 2.0 pads I had at my house before this installation would not fit the speed3 calipers because they were too small. There was also a size difference in the piston. It is not huge, but the chamber for brake fluid was definitely also a bit larger because I had to pump in more fluid than I lost when bleeding the brakes, even after bench filling the calipers.
Old 06-12-2011, 03:23 AM   #9
sicride8724
Send a message via Yahoo to sicride8724
Mmmmmm...... Car pron......... Great write-up! I want to do this conversion too.
STICKY!!!!1!!11!!!!!One!!!
sicride8724 is offline   Reply With Quote
Old 06-16-2011, 04:00 PM   #10
epic3
Moderator
epic3's Avatar
Send a message via AIM to epic3
Great write up! Bravo
Spread the community love
epic3 is offline   Reply With Quote
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Suspension / Brakes > Suspension / Brakes Technical Information, FAQ's, How-To's
